![]() | Home > Maintenance & Mods (L322) > Heated Seat. |
| KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848
Can't those with warm hands warm up those with a cold bottom? |
| comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1764
Interesting - I bought my 2010MY 4 days ago and have been back to question them on it. To me they hardly heat up at all to be honest...
| supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3964
I'm just gonna bump this to see if I get any answers. My 2010 seems to have an intermittent fan under the drivers seat, it's quite handy that you can just stick a finger in to see if it's spinning. Has anyone else had this? Is there a fix? Does anyone have the circuit diagram - or is there one in/on TOPIX.
Ah well, I found that as I can feel the fan under my seat, the filter has fallen off again, and if it doesn't start spinning on switch on I turn it of and turn it on again - the trick seems to be to turn it on slowly.
Sometimes the turning off turning on trick doesn't work in which case I have to turn off and turn on the car (restart) after a few miles as the IIDTool pointed me in the direction of the drivers seat heater losing contact (or maybe never even making contact) with the appropriate ECU.
| scwilson Member Since: 15 Dec 2014 Location: Dorset Posts: 240
I'll swap my 2003 for your 2010 if you like. My seats heat up super quick! |
| Lanby Member Since: 16 Jan 2013 Location: Leeds Posts: 11
Supershuttle, did you get a resolution to your heated seat problem as mine has started doing the same?
| CMJ Member Since: 10 Oct 2010 Location: Lancashire Posts: 208
Not sure this helps but we had similar issues with a vented seat. Turned out that a pipe joint between the base and seat back had come undone. Resulting in hot air being blown over one of the hearting unit causing the unit to cut off thinking it was warmer than it actually was. As I say not sure this helps but having spent 6 months getting to this stage including replacing one of the blowers my recommendation is to dis assemble the seat and see what is going on properly. 2013 L405 AB 4.4SDV8 Luxor/Ivory, 2007 Vogue TDV8 Epson Green/Sand, 2008 Vogue TDV8 Buckingham Blue/Sand, 2003 Vogue 4.4 LPG Epsom Green/Sage, 1998 Vogue SE 4.6 LPG Epsom Green/Cream |
| DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4352
Craig Are these the filters? https://www.island-4x4.co.uk/seat-filter-g...36870.html How many per seat? 1 or 2? Your post suggests 2per seat Ta Rob Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory" 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years I use www.glenrands.co.uk Great independent specialist! -------------------------------------------------- |
| Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16403
Thats them Rob, two per seat sir... One in the base and one behind the map flap in the back |
Cheers! I’ll check out the front 2.
| GGDR Member Since: 26 Nov 2016 Location: London Posts: 3561
A bit of light reading for you here Dr Rob:
| All times are GMT |
