Home > Technical (L322) > Splash Screen - On Too Long?
Shaun
England 2011 Range Rover Vogue 4.4 V8 Orkney Grey
Just noticed that if i unlock and then lock my car without putting the key in the ignition the logo stays on the screen for 10mins after locking. The car is a late 04 with touch screen. Recently installed a 2009/2010 nav disc, not sure if it has always done this as i have not had the car that long. Can this time be altered? Would it benefit from the fuse pulled to reset? Thanks. Confused
Post #26362 25th Aug 2010 1:21pm
delamo
England 2007 Range Rover Vogue SE TDV8 Tonga Green
My RR does this also Shaun - don't know why Question
Post #26366 25th Aug 2010 1:42pm
Once you have unlocked the car you are waking up all the systems in readiness to drive away. After locking these systems will slowly shut down in sequence taking a total of about 18 minutes until there is no longer a drain on the battery. Discovery 4 HSE
1998 90 TUL FFR Hard Top XD Wolf
1993 90 Tdi
*Gone: L405 4.4 VSE, L462 D5 HSE LUX, L663 Defender 110 HSE, Discovery 3 HSE, 2014MY Range Rover Sport 5.0 Supercharged AB Dynamic; L405 Exec Vogue SE 4.4, 5.0 Supercharged Autobiography, Defender TDCi XS CSW, Defender TD5 HT, Vogue SE TDV8, Vogue TD6, RRSport SC 4.2V8, Classic 3.9 Vogue Auto, Land Rover Series 3 SWB
Post #26387 25th Aug 2010 5:11pm
delamo
There's your answer Shaun - now we both know.
Thanks RRUK Thumbs Up
Post #26389 25th Aug 2010 5:30pm
If you want to test how long yours takes to switch off just pop the bonnet and 'fool' the bonnet open/light switch, then plug an ammeter into the battery, switch off and watch the amps slowly decreasing. Shouldn't take more than 20 minutes total.
If you are getting flat batteries then its a good way of proving a drain, how you would find out what system was draining it is anybody's guess! Discovery 4 HSE
1993 90 Tdi
Post #26390 25th Aug 2010 5:39pm
Shaun
Thanks for the reply, nice to know that its all OK.
Post #26392 25th Aug 2010 6:00pm
Tim in Scotland
Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland
2010 Range Rover Vogue TDV8 Stornoway Grey
Also when I had my first L322, and the 2 Sports the dealers have always recommended lowering the suspension to access mode if leaving the car for a while as this also tells the ECU's that you might not be returning for a long time and it puts everything into sleep mode sooner 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #26394 25th Aug 2010 6:58pm
