![]() | Home > Technical (L322) > fbh |
TheTowers Member Since: 07 Dec 2014 Location: SW England Posts: 4 ![]() ![]() ![]() |
My fbh seems to work on timer and for engine running warm up, but the 'manual' option is greyed out. Does that suggest it doesn't have the remote kit? The car didn't come with a fob. |
JAYBOY Member Since: 17 Oct 2012 Location: South Wales Posts: 2204 ![]() ![]() ![]() |
It may have a receiver and the previous owner may have lost the remote.
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3274 ![]() ![]() ![]() |
If you pm Dan at Duckworths he can get you the build sheet for your vehicle which will show if it originally had FBH and Remote. He will probably want your email address. John
ironhorse Member Since: 13 Dec 2013 Location: birmingham Posts: 355 ![]() ![]() ![]() |
mine does not get toasty de-frosts ok and lifts the temp ,but deffentley not toasty ran it with the blower fuse removed for 10 mins then put the fuse back in, only then did it get toasty so i think blower fans run to fast to heat the water up enough on a 30 min cycle wonder if fan speeds differ on later models |
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 ![]() ![]() |
Cowman
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2951 ![]() ![]() ![]() |
Mine isn't toasty either. It's not cold and the windows defrost. When I get in and switch in the heater, it blows warm(ish) air. Coming off a night shift, it's better than getting into a freezing car!
dont know if this reply is to late but i would not bother with the remote
J evro Member Since: 31 Aug 2014 Location: Kent Posts: 541 ![]() ![]() ![]() |
Way above my capabilities but a great mod |
jon3929 Member Since: 01 Jan 2015 Location: Weston Super Mare Posts: 62 ![]() ![]() ![]() |
I'm also in the 'FBH not working' club |
Ouch!!!
I have tried pulling fuse 59, but it makes no difference |
