![]() | Home > Wheels & Tyres > RR snow chains or LR Snow Traction System |
| Martin Site Admin Member Since: 24 Mar 2007 Location: Hook Norton Posts: 1673
The issue with traditional chains is that they require good clearance between the wheel and suspension/brake components.
| GenevaRR Member Since: 28 Apr 2013 Location: Oundle Posts: 11
Thanks I will look up the Spider Spykes.
Check the manual, I have vague recollections that 1 pair is enough. |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35874
the FF has a 50/50 power distribution to the front and rear wheels so i would put these on both axles to be safe. ... - .- -.
| kingpleb Member Since: 07 Jun 2011 Location: Maybe here. Maybe there, I get everywhere! Posts: 8455
Chains would be good if you had a scruffy set of alloy wheels as well as they invariably will leave some marks on them.
I thought about 19 inch rims but I was told that they would not fit over the large brake callipers on the Westminster.
I looked up the Spider Spikes on the link provided - thanks
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8788
Noooo, only put chains on the rear!!!
| CSK Member Since: 15 Oct 2010 Location: St Tropez Posts: 750
Land Rover recommends fitting the snow traction system on the front wheels only for the L322 and on the back wheels only for the L405. I have no idea why the recommendations are different from one generation to the other but that's what the official recommendation is.
| Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16403
I have a spare set somewhere... |
I believe there is a certain style of 19" wheels that just clear those calipers for this express purpose, they are 11 spoke I think and mentioned in a post in general when someone looked at a 2010 sc that had the wrong wheels fitted to it.. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
These ones Will |
| Alistair Member Since: 11 Feb 2011 Location: Peterborough / Alicante / Andorra Posts: 8135
As stated already - manual says rear axle only - there isn't enough clearance on the fronts
Thanks for pic
