![]() | Home > Maintenance & Mods (L322) > Gurgling sound from around the sunroof area |
scwilson Member Since: 15 Dec 2014 Location: Dorset Posts: 240 ![]() ![]() ![]() |
I still hear this in the mornings or when it's rained. Sounds as if it's coming from above the sunroof or certainly the sunroof area. Does anyone know what this is? It stops after a while but why does it gurgle? |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2280 ![]() ![]() ![]() |
Its the drain partially blocked mine does it too haven't gotten round to clearing it - it gurgles as the air bubbles back up think the remedy is to use strimmer nylon to gentle unclog it will prob be at the bottom |
oh ok |
Interestingly I noticed today while it was gurgling, if I turned the blowers off, it stopped, switched them back on and the sound started again. Did this several times to make sure. Is there a pump of some sort connected to the sunroof area that is driven by the blowers? |
