Home > Technical (L322) > Bl00dy FBH again
Page 2 of 3 <123>
JAYBOY
Wales 2017 Range Rover Autobiography 5.0 SC V8 Corris Grey
DMRR
It runs but only for 2-4 Mins at a time.
There is something in the electronics that is stopping it.
There is a Battery monitoring system on them and they think mine could be Censored
Its just a waiting game for my in the mean time.
To say I'm a little pi55ed off is an under statement.
Craig
They are not claiming on my warranty for all this work. They are doing it because they have told me every time that its working and every time i have proved them wrong. Its a customer relations exercise for me.
I have no problem going down there and kicking up a right fuss in the showroom.
Because Land rover are now involved they all need to see it done and dusted. 2020 Porsche Panamera Turbo Hybrid (V FAST)
2017 Range Rover Autobiography 5.0 V8
2018 JCW Mini Cooper
2018 Skoda VRS
Post #307786 24th Jan 2015 10:55pm
If they can get it to run with the diagnostic tool, or at all then it sounds like the problem could be elsewhere, on the few 4.4's I have had a tool around in, off forecourts, they have invariably displayed the low battery warning before we started out!
That they are now pointing towards the battery management may be a good sign, running for 4 mins should be unlikely to drop the voltage low enough to shut it down. Surely they should be able to rule this in or out by simply connecting to a constant supply? There is nothing that can't be fixed with a hammer😜😜
Post #307825 25th Jan 2015 9:17am
vaz
United Kingdom 2007 Range Rover Vogue TDV8 Java Black
Is it getting fuel?
The only reason I ask is, ours runs for around 3 minutes then stops. This is the normal cycle time from initial starting up, then fuel dosing pump starting, heater detecting flame and then going into full operation mode. When it shuts down, it should take a minute or two to purge the fuel then cool down and shut off.
I have been playing about with ours all this weekend. I removed the unit, stripped it down and cleaned the combustion chamber (sooted up). The heat exchanger was spotless. Re-built it back up and fitted to the car.
Fired it up and it goes through the cycle of starting up, but then no fuel, runs for a further minute or two then shuts down.
Upon checking the dosing pump, it wasn't working. Located the dosing pump (a pig to get to) above the rear differential. Removed it and checked the pump, pump works fine, re-fitted it but still doesn't work. After looking around the internet, the dosing pump receives its dosing level from the heater unit itself. There are plenty of topics and comments about the unit and the circuit board. Looks like ours is duff as there are a couple of resistors on the board that go open circuit so I will have to strip the unit down again next weekend to check the board and replace said resistors.
Could be a fuel problem with yours, but if they have fitted a new heater unit, it could be the wiring.
They should be able to test it with the Webasto diagnostic kit and see exactly what is happening.
Steve. 1968 Series IIA Pastel Green, nearly there project
Post #308308 26th Jan 2015 7:48pm
JAYBOY
Steve
Thanks for input.
Mine is a completely new system, pump heater the lot. I think its the battery monitoring system.
They haven't called me today so its not getting any better in my eyes Banging Head Banging Head 2020 Porsche Panamera Turbo Hybrid (V FAST)
2018 Skoda VRS
Post #308312 26th Jan 2015 7:55pm
DMRR
On the plus side the weather is improving, so you won't need it by the time they get the vehicle back to you Whistle Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #308439 27th Jan 2015 8:59am
J evro
England 2008 Range Rover Vogue SE TDV8 Stornoway Grey
Seems there would be a great opportunity for someone on here that could take our cars and sort out these FBH problems, surprised no one has offered their services
any takers?
Post #308528 27th Jan 2015 4:08pm
ironhorse
United Kingdom 2003 Range Rover Vogue 4.4 V8 Giverny Green
there are no takers
just because the landrover software is the nightmare, if the stealer cant sort it out with the factory diagnostic kit and webasto will not sell landrover programed ones off the shelf what hope have DIY,ers got
the heater side of things are easy to fault find and repair but connect them to a late ff you may aswell just give up on parking heat
Post #308550 27th Jan 2015 5:34pm
Ningr
United Kingdom 2005 Range Rover Vogue 4.4 V8 Adriatic Blue
These units seem to be similar to the units used on our diesel trains.
Our main problem was water leaks due to poor hose connections.
So …. ask if they have tested the water system under pressure as the boiler unit will fire but due to no water pressure the sensor will cancel the signal to prevent the boiler from over heating and sooting up.
If its any use to you in your problem.
Post #308576 27th Jan 2015 7:47pm
JAYBOY
Still no car Big Cry Big Cry
They have however had it all working Rolling Eyes
They are saying that there nothing wrong with the FBH but the battery monitoring system is at fault.
Is this an easy fix Question 2020 Porsche Panamera Turbo Hybrid (V FAST)
2018 Skoda VRS
Post #309813 1st Feb 2015 8:29pm
B100
I know I'm four years late on this, but somebody may be able to make use of what I have discovered. The FBH will only work if the battery voltage is high enough - otherwise there is a risk the FBH flattens the battery and you won't be able to start the car. Yes - I guess you already know this. I presume that the heating designers have erred on the cautious side and set the voltage threshold on the high side.
In practice, this means that you have to drive for at least half an hour if you have a new or good battery and possibly for longer if the battery is a few years old or bit below par before you can use the FBH ? So don't expect to be able to warm your car in the morning unless you've given the car a really good run the night before.
I've got around this problem on an older Landrover by powering the FBH from an auxiliary battery. The options for keeping this charged are a split relay charger or (my preferred) a solar panel.
Post #505064 13th Feb 2019 10:55pm
Norway
Norway 2003 Range Rover Vogue Td6 Adriatic Blue
How did this end? -03V td6
-72 Cadillac Coupe DeVille 7,7liter.
Post #505459 17th Feb 2019 11:37am
Mine is not kicking in at the moment. I’m going to put the car on the Ctek tonight to see what it’s like in the week. I guess that the voltage is a bit low. There is nothing that can't be fixed with a hammer😜😜
Post #505463 17th Feb 2019 12:02pm
B100
You can do a simple basic check. Use a battery charger to be certain the battery is fully charged. If the FBH is OK, then it should start and run with no problems. If it won't start, then there are only three possibilities: the battery is on its way out, the FBH is faulty, or there is no fuel supply to the FBH. My experience of Webastos is that they are very reliable - apart from the water circulation pump. Give them fuel and a 12v supply and they invariably work fine. If it starts and runs for just a few minutes then shuts down, put your hands on the heater pipes to see how hot they are. If they are hot, then the chance is the water circulation pump has failed. The built-in temperature switch will have detected the water getting too hot and will shut the heater down.
Post #505467 17th Feb 2019 12:24pm
JAYBOY
It was the battery. Land rover admitted they had a bad batch of batteries, they had changed mine three times.
They installed a different brand and it worked faultlessly for the time i owned the car. Thumbs Up 2020 Porsche Panamera Turbo Hybrid (V FAST)
2018 Skoda VRS
Post #505503 17th Feb 2019 7:48pm
GGDR
Guys don't forget the FBH won't work if fuel level is too low.
Not sure, might be 1/4 of a tank.
. Cheers, Greg
Post #505504 17th Feb 2019 8:07pm
Page 2 of 3 <123>
