![]() | Home > Off Topic > Any mountain bikers here ? |
Ideally you'll want to stick to the same frame as then you know it will all bolt off and onto the new one but there are likley other frames that all the bits will fit onto, it depends on the rear suspension mounting points more than anything.
Johnte Member Since: 23 Aug 2010 Location: North Yorkshire Posts: 746 ![]() ![]() |
Thanks.. I think you're maybe right - if I can find a frame exactly the same, it would make it a much simpler job for me |
It's always worth an ask as you'd expect them to last a bit longer |
A1GSS Member Since: 24 Dec 2010 Location: Saffron Walden, Essex Posts: 1973 ![]() ![]() |
I'd have thought it was an ideal opportunity to go shopping for a new one... |
CEEGEE Member Since: 20 Mar 2013 Location: Yorkshire Posts: 685 ![]() ![]() |
I have built a few road and mountain bikes up - the only part which is likely to be restrictive (but still not unique) is the rear suspension, otherwise parts should be easily "transferable" - but you'll obviously have to re-cable it.
GraemeC Member Since: 01 Jul 2012 Location: Chester Posts: 836 ![]() ![]() ![]() |
All the parts should be interchangeable with a new frame except the rear Genius shock, which is a specific Scott design for the Ransom (I have a carbon Ransom - awesome bike, I love it!)
I suppose ideally we should be looking for a new one, but he's really getting into road biking now, and would like to upgrade his road bike. So is desperately saving his paper round money.
Sounds like a plan - I bought a second-hand winter road frame off ebay, and its been fine |
