![]() | Home > Technical (L322) > TDV8 Turbo Issues |
DavidC Member Since: 08 Oct 2012 Location: Beds Posts: 66 ![]() ![]() ![]() |
My turbo failed went without the top houses ever failing.
They will be linked yes... Every one I've heard of has followed am EGR replacement... That said! Ive replaced many EGR's WITHOUT the turbo failing afterwards too... |
fanders Member Since: 10 Jul 2013 Location: Hants, UK Posts: 322 ![]() ![]() ![]() |
What would the difference in cost be between replacing both EGRs compared to both EGRs and both turbos? A lot, I imagine?
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1863 ![]() ![]() |
How many turbos have you replaced that have not had EGR issues? |
Ziggy Member Since: 26 Dec 2011 Location: West midlands UK /sydney AU Posts: 265 ![]() ![]() |
Ok so intercooler hoses as a service item (reduce risk) Cam-Tech any thoughts on why the turbos fail After replacing the EGR So are there any pre-emptive measures you can take with the EGR to minimize possible Turbo failure Zigg "Those who cannot remember the past are condemned to repeat it." George Santayana Puts away his cloth cap and donkey jacket Goes and sits in the naughty corner |
Have a read through this thread here: http://www.fullfatrr.com/forum/topic26886.html
Markos01 Member Since: 17 Jan 2015 Location: Fife Posts: 6 ![]() ![]() ![]() |
Had 2new egr valves replace 3weeks ago on tdv8vouge now just broken down Kinross oil pouring out the air filter box |
NONE! BUT that said... We only specialise in FF's so, very rarely see any Sport models which suffer differently as have different turbo's... ![]() |
What you guys saying spending £1000 on new egr valves,may have caused the turbo to fail |
I have done 2 pairs of turbos on FFRR's, one of which had not had any EGR issues since new, and the other had a single valve done 30k miles previous. I still fail to see the link between the two |
More to the point, £1000? ![]() |
Let me clarify... That was NONE on FF's that have not had EGR issues... compared to upwards of a dozen in the last 24 months that have Mikey! And MOST of the EGR's were not done here! |
