|  | Home > Technical (L322) > iidtool height adjustment |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8826      | Where are you measuring from Stan, should measure from center of wheel to bottom of wheel arch, not from ground as that will vary due to tyre pressure, load in car, amount of petrol etc etc... basically anything that would change the depth of the tyres sidewall... Pete
|  12th Jan 2015 7:04pm |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35883    | always measure from bottom of rim to top of wheel arch [the metal bit] ... - .- -.
|  12th Jan 2015 7:09pm |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8826      | Yeah that'll work.... I can't bend down that low  | ||
|  12th Jan 2015 7:11pm |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35883    | i'm sure there's a logical reason not to do it that way.. ... - .- -.
|  12th Jan 2015 7:30pm |
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434    | measure from wheel centre stan, this removes any diameter issues with your rim   | ||
|  12th Jan 2015 8:02pm |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35883    | it wont affect the measurement on all four corners if i measure from the same position and as my heights are near to your 'chart' figures ,thats ok with me..
|  12th Jan 2015 8:29pm |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35883    | is there any way of defaulting the heights to the original OE spec? ... - .- -.
|  17th Jan 2015 8:20am |
| Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1885    | I find it easiest to set the heights to the approx heights, then do a full calibration    | ||
|  17th Jan 2015 8:59am |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35883    | thanks mikey,
|  17th Jan 2015 12:56pm |
| Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1885    | In a perfect world, all sensors would read 0mm
|  17th Jan 2015 1:25pm |
| All times are GMT | < Previous Topic | Next Topic > |
| Posting Rules
