Home > Technical (L322) > Newbie question number 4
Andy3681
United Kingdom 2005 Range Rover Vogue Td6 Cairns Blue
As said make sure it's plugged in and in the right place when I first had mine it didnt work but had just had a new screen, the sensor was in the wrong place and unplugged. Mine was a blue one! Smile
Post #304701 13th Jan 2015 10:08am
A1GSS
Cam-Tech-Craig wrote:
The funny thing is, i had the same problem with one of my FF's after a replacement screen was fitted (not well) and the sensor was not clipped in place correctly...
Same. AA Windscreens. Was a pukka LR spare screen but fitted badly. Graham
____
Gone: 10MY L320 RR Sport HSE, Ipanema Sand
Gone: 20MY Jaguar iPace HSE, Silicon Silver
Gone: 17MY RR Evoque SE Tech, Loire Blue
Gone: 08MY Discovery 3 XS, Stornoway Grey
Gone: 07MY FFRR TDV8 Vogue, Stornoway Grey
Post #304708 13th Jan 2015 10:24am
Ditto Rolling Eyes Thumbs Up
Post #304710 13th Jan 2015 10:26am
Bluestu33
United Kingdom 2014 Range Rover Vogue SE SDV8 Loire Blue
Thanks all!
The car is in the garage today getting the smokey exhaust looked at. I will give this a go tomorrow and let you know how I got on.
Post #304734 13th Jan 2015 11:59am
Bluestu33
I took off the cover and checked the connection and the sensor box and all seems in position and connected. I a
So ripped off the mirror, but have managed to put that back. I've tested the wipers and no different, also, at the moment it is full sun, yet the auto lights still come on, so it must be that the sensor is knackered.
I took out the fuse, but that controls the wipers and the wash so without nothing. So it seems I cannot disable the auto wipe and just use the manual intermittent until the sensor is replaced.
One thing I did notice (although it maybe irrelevant) is that there is a hole on the sensor area on the screen to the left of the sensor box, could it be the sensor is not in it's correct position.
Post #305012 14th Jan 2015 12:41pm
'nail on head' is the expression on this one..that hole certainly looks like the aperture for the sensor, canyou move the unit to the left? ... - .- -.
Post #305013 14th Jan 2015 12:45pm
Bluestu33
No, it will not budge.
Can the sensor be easily removed and re stuck?
Post #305020 14th Jan 2015 12:55pm
it appears to be bonded on,
maybe there is 'outside access' behind the unit, can you see from the outside.. ... - .- -.
Post #305023 14th Jan 2015 12:59pm
Bluestu33
No, nothing.
Do you think that it would be best for the windscreen to be replaced?
Post #305032 14th Jan 2015 1:32pm
i wouldnt have thought so...i sure someone will come along and explain how to easily get the unit off the glass.. ... - .- -.
Post #305043 14th Jan 2015 2:00pm
