Home > Wheels & Tyres > 53 offset non-TPMS wheels on TPMS equipped FF?
Beau
United Kingdom 2008 Range Rover Vogue SE TDV8 Buckingham Blue
Hi,
This is further to my other thread looking for winter wheels.
I think from searching on here that the wheels Ken has for sale will fit on my 2008MY TDV8 but before I make the trek up from Dorset to try them on can the collective confirm or deny?
They are 20 inch, 8.5J width, 53ET offset genuine D4 black series wheels (so weight should be fine)
Shod with 255/50 R20 109V Continental CrossContact Winter (non-TPMS valves) so approved tyres for the FF in the same size as my existing.
So the only differences to my existing Pirelli Scorpions are:
1. the offset - 53 instead of 58 - which, as I understand means they will sit 5mm further out into the arches
2. the non-TPMS valves which will cause an error code on the dash? Interestingly my TPMS valves are corroding - only just understood the significance of this whilst searching on here. As my FF had a full LR warranty put on in July 2014 should these be replaced FOC? Or if I am having non-TPMS winter wheels am I better to get non-TPMS valves on my regular wheels and get the stealer to deactivate TPMS?
Thanks all in advance,
Beau
Post #304993 14th Jan 2015 1:00pm
FF rims are 53 et offset so no difference there as is the tyre size which is the same , but i cant recall seeing d4 wheels on a FF.. ... - .- -.
Post #304996 14th Jan 2015 1:06pm
Beau
Thanks Stan - I was sure my 7 spoke 20 inchers are 58 but there you go!
Any thoughts about the TPMS?
Post #305067 14th Jan 2015 4:02pm
they might be 57 et off set if they are RRS wheels..
as for tpms, i took mine off and disabled it in the ccf with the iidtool, waste of time in my case because of all the errors i kept getting.. ... - .- -.
Post #305069 14th Jan 2015 4:10pm
Beau
Thanks Stan - very much appreciated. Thumbs Up
Post #305120 14th Jan 2015 8:29pm
miggit
Shocked I've just fitted TPMS Shocked
But it is an after sales system, and only relies on the FF for 12v Laughing Yesterday I couldn't spell Engineer... Today I are one!
Post #305123 14th Jan 2015 8:34pm
