Home > Off Topic - Other Cars > Freelander problem assistance required
Andy_J
Scotland 2007 Range Rover Vogue SE TDV8 Java Black
Earlier this week I had to assist one of my friends as her Freelander would not start.
It is a 1.8 Petrol Freelander 1 registered in 2000. Since rescuing her my friend has discovered if she leaves the Freelander open/unlocked after about 3-4 hours it will start.
Anyone come across this issue on a Freelander 1? I am going over on Sunday to check connections to starter, ignition switch, battery etc. But if anyone seen this before may save me some time.
NB when it doesn't start all ignition lights come on, alarm flashing light goes off, but nothing when you turn the key, no click from the starter/solenoid, not spinning of the engine 56 TDV8 Vogue SE
9 Freelanders, 2x 2002 TD4ES, 2001 TD4, 2002 1.8GS, 2000 XEDI, 2x 2000 1.8ES, 2004 1.8 & 2000 1.8 GS (rolled)
91 Lotus Carlton (sold)
90 Lotus Elan (BRG)
Post #307546 23rd Jan 2015 11:00pm
DMRR
Camshaft sensor. Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #307550 23rd Jan 2015 11:06pm
Andy_J
Thanks. maybe a daft question, but why does leaving it unlocked affect the camshaft sensor? 56 TDV8 Vogue SE
90 Lotus Elan (BRG)
Post #307566 23rd Jan 2015 11:37pm
Mikey
Loose terminal on the starter motor is the most likely culprit
Bought a 1.8 in Edinburgh, started fine but had HG issues, so stopped every 20 miles to check water level.
The first twice we stopped, it started fine. Last time we stopped, it wouldn't restart, with no click at all for the starter motor. A few wiggles of the wire had it making a better contact, and worked fine after that
Post #307611 24th Jan 2015 9:08am
Andy_J
Fixed, spot on Mikey Thumbs Up was a loose connection on the solenoid. 56 TDV8 Vogue SE
90 Lotus Elan (BRG)
Post #307901 25th Jan 2015 6:41pm
Mikey
Seen plenty of them do that
Post #307916 25th Jan 2015 7:33pm
Sandyt
Good its sorted another one I had on my p38 was the cable from the battery to the started had internal corrosion so giving it a wiggle and it started for a while replaced the cables never had it comer back might be worth a look
Post #307937 25th Jan 2015 8:20pm
