Home > Technical (L322) > Engine cranking not starting
^ Alternator Thumbs Up
Post #312261 12th Feb 2015 9:09am
William97841
Well I did an alternator test but just with engine running and got 14.1 volt I thought it had to be 14.4 could be wrong though.
That's my next port of call because I've got the cable harness from battery to the glow plug relay and ecu cable because their in one lead. Ebajema I might be abit thick here but which clamp are you talking about on the battery or alternator??
Thanks for ur help 😉
Post #312509 13th Feb 2015 6:26pm
William97841
You really think alternator gazellio?? Do they go wrong much? And how to i correctly tell it's the alternator?
Post #312511 13th Feb 2015 6:29pm
14.1 volts is ok, anything between 14 and 14.5 is acceptable.. ... - .- -.
Post #312514 13th Feb 2015 6:32pm
William97841
Hmmm looks like I'm in abit of a pickle lol. It must be something electrical as for the cut out from cold it took 1hr while on idle to cut out then about 15mins worth of driving it cut out. But when it did cut out I tested it and only 11.75 volt so perhaps faulty alternator or the cabling I hope. Any other thoughts??
Post #312517 13th Feb 2015 6:41pm
I presume your battery terminals are tight?
Have you checked the connection from the battery -ve terminal to the body?
Have you checked the connections to and from the +ve jump post?
Have you checked the connections to the alternator?
Can you check the resistance between the engine block and the battery earth terminal?
You could try connecting a jump lead between the engine block, eg a bolt head etc, and the -ve jump post and see if any improvement.
If you run the engine at 2000rpm with nothing switched on what is the voltage across the battery terminals?
What is the voltage with the engine idling with nothing switched on?
Post #312518 13th Feb 2015 7:10pm
William97841
Well we have another problem now. Put the battery on charge got 100% put it back into the car and now the car cracks for 5 seconds and stops completely!!! Repeat it again does the same thing cranks for 5seconds then stops!!!
Post #313149 16th Feb 2015 10:12pm
William97841
For people that want to know I've replaced the regulator and all seems fine phew...now just gotta get the sat nav working
Post #313572 19th Feb 2015 12:50am
