Home > eBay & Bargain Spots > Bargain oils
Bargain oils
Spotted that car parts 4 less have shell helix professional af 5w30 on offer at the moment. Not sure if its the correct one as it seems to be listed as a3/b3 but I bought what I think is the same from Ecp the other day and it was a1 and ford 913b compliant.
Worth a look http://www.carparts4less.co.uk/cp4l/p/acce...mp;cc5_247
Seems about 1/2 price......seems to be this one but wrongly listed
http://www.shell.co.uk/gbr/products-servic...-5w30.html
So correct for 3.6 tdv8.
Have ordered some to see. There is nothing that can't be fixed with a hammer😜😜
Post #309123 29th Jan 2015 9:46pm
Mikey
Have ordered some too Thumbs Up
Correct grade is A1 for the 3.6, as per Shell website, though A5 is almost exactly the same oil, with a higher sheer rate 2.6mPa for A1, and 2.9mPa for A5
Quote:
A1/B1 Stable, stay-in-grade oil intended for use at extended drain intervals in gasoline engines and car & light van diesel engines specifically designed to be capable of using low friction low viscosity oils with a high temperature / high shear rate viscosity
Quote:
A5/B5 Stable, stay-in-grade oil intended for use at extended drain intervals in high performance gasoline engines and car & light van diesel engines designed to be capable of using low friction low viscosity oils with a High temperature / High shear rate (HTHS)
Post #309143 29th Jan 2015 10:54pm
oil turned up today Thumbs Up Thumbs Up
Is as suspected 5L of Shel Helix HX7 Professional AF 5w-30. Compliant with Ford WSS-M2C-913-A/B which means it is spot on for the TDV8 and 4.2 SC (according to the handbook i have infront of me.
Grab a bargain if it is still there.... There is nothing that can't be fixed with a hammer😜😜
Post #309999 2nd Feb 2015 5:39pm
Mikey
Glad I had ordered 50L of it now. Won't go to waste, as it is also suitable for the 2.7 TDV6 Whistle
Post #310000 2nd Feb 2015 5:52pm
johnboyairey
that IS a bargain! and its 5 litre pots too.
Post #310001 2nd Feb 2015 5:52pm
Yep was just going to order a load for the Disco too..... There is nothing that can't be fixed with a hammer😜😜
Post #310003 2nd Feb 2015 5:55pm
Ordered 2!
Cheers for the heads up Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #310004 2nd Feb 2015 5:56pm
tony66
Scotland 2005 Range Rover HSE Td6 Tonga Green
oil
wonder if this would be any good for the td6 or indeed my 530 e61[dpf removed and remapped so doesnt need low sap oil any longer i wouldnt think..]?
Post #310178 3rd Feb 2015 11:16am
Mikey
This is a Ford spec oil, you would need a BMW spec
No idea what the actual difference is in specs mind...
Post #310318 3rd Feb 2015 8:36pm
tony66
oil
me neither tbh-i know if dpf present it should be a low sap oil but...
i think for the extra few quid i"ll put the correct spec in it anyway i suppose
but hate missing a bargain lol
Post #310325 3rd Feb 2015 8:49pm
pld118
northernmonkeyjones wrote:
... 5L of Shel Helix HX7 Professional AF 5W-30 ... spot on for the TDV8 and 4.2 SC ...
Gents, reading this with some interest as the SC is due to be serviced next week.
A. Presumably you can take your own oil to a main dealer?
B. More importantly though, seems to be some confusing (to me anyway) data if anyone can please enlighten me. This Shell link shows the Helix HX7 to be 'semi synthetic'. Is it not best to use fully synthetic?
Bow down
Post #310357 3rd Feb 2015 10:13pm
Won't know where you are seeing semi-synth on that Ryan. Edit got it now.....
Meets the criteria for 913-b which is the one needed.
I took the oil in to the dealer, and they charged me £69 to do the swap including the filter...... Originally the quoted me £227 for an oil change, so go figure how much the charge for the oils. Our Md uses helix.
Had a look and from what I can see non of the helix ultra range of fully synth meet the right specs. Better specs yes by exact right ones for the 3.6, no. Stick the 3.6 in the shell lube search and it comes up with a choice of either hx7 or the fully synth ultra. So I presume both will do though the ultra actually has a higher ford spec on it.....?
I'm planning on running an extra change per year in any case so as long as it has the correct spec on it I'm happy. There is nothing that can't be fixed with a hammer😜😜
Post #310358 3rd Feb 2015 10:19pm
pld118
Cheers nmj Thumbs Up
Post #310426 4th Feb 2015 6:50am
alx
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Nara Bronze
Excellent deal, thank you. Ordered 5 canisters.
Don't forget to use the Promo Code at the checkout for further discount:
Spend Over £50 and get £5 off - CP5LESS
Spend Over £75 and get £10 off - CP10LESS
Spend Over £100 and get £15 off - CP15LESS
Post #310507 4th Feb 2015 2:27pm
Mikey
Now you tell us Evil or Very Mad Big Cry
Post #310565 4th Feb 2015 4:21pm
