![]() | Home > Technical (L322) > FBH relay question |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3983 ![]() ![]() ![]() |
No relay involved.
sasdiscos Member Since: 16 Oct 2014 Location: Northants Posts: 286 ![]() ![]() ![]() |
I thought it was permeant live, and then w bus for the control.
mbmarkyb Member Since: 18 Jan 2015 Location: basingstoke Posts: 22 ![]() ![]() ![]() |
Found it in rave to thank you for posting. I think.I either have a ecu board problem on the fbh as it also suffers with fan being on when you.open doors etc or a pump or a connection . will see if I can access the pump and.test for power etc this afternoon |
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 ![]() ![]() |
http://www.fullfatrr.com/forum/topic23111.html?highlight=paulb |
Thanks for the responses and links will get in touch with mike |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6830 ![]() ![]() ![]() |
Doh, sorry, misread FBH for FSR |
ironhorse Member Since: 13 Dec 2013 Location: birmingham Posts: 355 ![]() ![]() ![]() |
FBH fuel pump is not in the tank,its on a rubber bracket above and to the front of the tank
ta for info again. got the pump out . was just a mass of rust . tried on a 12v source and just click nothing tested connector and I have power . New pump ordered. I am still suspecting pub but will change this first |
the pump does just click once when you power it up
if that is the case then it maybe ok apart from one end of the metal pipe just broke off.
saw a few like this and still working
