Home > Technical (L322) > headlight beam
headlight beam
a question to those that might know, if i adjust my headlight beams so they both point right in front of me and to the middle of the left hand side road [like bmw flat beams] , will i need to use the tourist lever if i drive in europe.. ... - .- -.
Post #310932 5th Feb 2015 6:48pm
Weegie
Won't you still have the "pitch up" on the left side of the spread which would mean that even if you move everything to the right you would still have the likelihood of dazzling oncoming traffic.
I may have misunderstood what you are saying but it seems to me that using the "tourist" system would be much simpler.
As you know, it makes them flat beam and I use it here with no problems. It even passes the MOT equivalent. John
GAP iiD BT-Sold
Post #310941 5th Feb 2015 7:16pm
Sandyt
Re: headlight beam
What tourist lever is that Stan
Post #310942 5th Feb 2015 7:19pm
@john, agreed re using the tourist lever but my thoughts are to pull the nearside light to the right and the offside light to the left so they both project straight in front, unless the headlight glass it self stops this kind of beam pattern..
@sandy , the tourist lever is in each headlight and blanks off part of the beam so you dont dazzle the euro drivers.
Post #310945 5th Feb 2015 7:26pm
Weegie
Don't know whether the glass would affect it. As there is quite a bit involved with the headlights eg. level adjustment, I think you might run into complications.
As I said, you would still have the "pitch up" on the left beam and no flat top. John
GAP iiD BT-Sold
Post #310950 5th Feb 2015 7:34pm
my beams have a kinda ^ shape and i have adaptive headlights so hence the initial question, just curious Wink ... ... - .- -.
Post #310968 5th Feb 2015 8:19pm
Weegie
Thumbs Up John
GAP iiD BT-Sold
Post #310973 5th Feb 2015 8:26pm
Sandyt
I go over to France a lot and have just used sticky tape mmm who is the numpty of the week then - didn't know they existed thanks Stan
Post #310974 5th Feb 2015 8:30pm
have you AFS headlights Sandy? ... - .- -.
Post #310975 5th Feb 2015 8:32pm
Sandyt
I think so Stan they go through the dance routine on switch on
Post #310984 5th Feb 2015 8:54pm
Sandyt
Its a July 2007 4.2 s/c
Post #310985 5th Feb 2015 8:54pm
ah , then putting tape on the lens wont work cos the headlights turn when you turn Wink ... ... - .- -.
Post #310987 5th Feb 2015 9:01pm
