![]() | Home > Technical (L322) > 2004 V8 - Cut Out - Now Wont Start |
| dan_uk_1984 Member Since: 12 Nov 2008 Location: Bude, Cornwall Posts: 4014
New one to me, completely flummoxed:
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35874
wiring loom Dan? ... - .- -.
Thanks Stan, all looks good.
http://www.fullfatrr.com/forum/topic23644....aft+sensor
Unfortunately Stan, both of those posts have no resolution, I assume after Vento got the car fixed he left the forum |
Got it booked in to a garage to get the crankshaft sensor replaced, will tow it with the other L322 following the towing procedure. |
| johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035
the crankshaft sensor is a two minute job, two allen head bolts, and a connector. Then pull it out...i did mine at off road height, spare wheel under the sidestep, lay under step, and reached under. mine was stranded, so it was easiest option. as said, i needed a camshaft sensor, (another 2 minute job,) i couldn't find a secondhander, and new was an order in job, so i found that an ebay seller did them new for a m62 engine, but they had a male socket on, not the famale i needed, so as it was only £15 each, i solderered them to the old females, and ---VROOOM!
Unfortunately it turns out I have no compression on one bank - this means the valves are not operating as they should.
To follow up - the plastic timing chain guides (yes, plastic, Thanks BMW!) had failed and become snagged in the chain and ripped off, the chain was then allowed to move, which pretty much destroyed everything.
| verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952
Sad to read this |
| Prepros123 Member Since: 28 Sep 2014 Location: Cornwall Posts: 35
Had this happen to my last one. Timing chain jumped because of worn plastic guides. Is it feasible to have these changed as a preventative measure though I should imagine it's a PITA of a job |
| Starberg Member Since: 08 Jan 2015 Location: Karlskrona Posts: 70
Sorry to hear that mate!
Mine happened at 160000 odd so no idea what expectation is |
