Home > Camping, Caravanning and Holidays > Pulling the tintent!
Page 2 of 6 <123456>
IanV8
Scotland 2011 Range Rover Vogue SE TDV8 Santorini Black
noddy wrote:
I think you're over the 85% rule there!
It's not a rule it's purely a recommendation for those new to towing.
Assuming the RR is 2800 then it is 86%.
Ian
Post #313192 17th Feb 2015 9:36am
^ yep, it comes from the caravan club recommendations, which are that if you are new to towing then you should stick to an 85% ratio for more experienced tow car drivers 100% is ok. You are legal (if you have a pre 1997 license) upto the tow cars stated towing limit, 3500kg, so long as you are also within the max GTW of the outfit (i.e. the car isn't also overloaded).
Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #313319 17th Feb 2015 8:07pm
Andy
I wasn't talking literally when I said that!
Post #314401 22nd Feb 2015 9:28pm
Fish
United Kingdom 2007 Range Rover Vogue TDV8 Rimini Red
I had mine out for the 2nd time with the FF over weekend. I used to think the D2 was good but the FF is in a different league. Everything about it is better, I still can't quite believe the difference, it's effortless Thumbs Up
Not the best picture but I was trying to take it one handed on the phone while holding the dogs in the other hand Embarassed
Post #329553 27th May 2015 7:45am
mzplcg
IanV8 wrote:
The RR is awesome as a tow car, the van is 2400kg.
What chassis is that on then? Both the BPW and the ALKO have a pair of 1000KG axles. Add either 100 (Alko) or 150 (BPW) kilos for the noseweight and it's still over the chassis makers design weight.
Post #329555 27th May 2015 8:07am
IanV8
It's on a BPW with axles rated at 1200.
There are Alko chassis about with 2300 payloads, Vanmaster for example.
Ian
Post #329573 27th May 2015 9:13am
Andrew5331
L200 not for much longer
[image]Here is my l200 but not for much longer as I pick up my rrtdv8 4.4
On Wednesday I cantwait[/img]
Post #330467 1st Jun 2015 9:25pm
n1cktdv8
Just back from a week on Anglesey, as always a solid tow at 22mpg fully laden with bikes and everything for 5 people.
Thumbs Up Is this where I put the car details and a bit about myself ?........
Post #330496 1st Jun 2015 11:18pm
Woke up his weekend to water running in the roof of my 2010 lunar. Rolling Eyes
The mastic had hardened on the vent over the microwave, and once unscrewed I could just lift it off. Easy fix at home as I have sealants galore in the garage. Had to find the local caravan shop in Witney, fortunately they had some Sikka type sealant which would do the job.
All sorted but a bit of a pita when it was Censored down!
Check your sealants! There is nothing that can't be fixed with a hammer😜😜
Post #330591 2nd Jun 2015 3:33pm
n1cktdv8
+1 on that. Really should be Sikaflex all over as it doesn't set but worth a check.
Our 'van is out most weekends so has a regular check but if they get damp it can spread like crazy Is this where I put the car details and a bit about myself ?........
Post #330592 2nd Jun 2015 3:37pm
Also Just re done the front rail above the windows today, as that had also dried at one end and was really crusty underneath. As it is a pita to clean it all off I re did it in IDL 99 which is what it was in the first place. Easy job but total ball ache to get all of the mastic which squeezes out off the front of the van.
The side rails are sikkaflex but for some reason the front is not Rolling Eyes neither are the top fittings.
Should be ok for another 5 years now! Going to have a check on the rest of the roof this week when I get chance. It still has some water ingress warranty left, but it's too much faf to take it to the dealer!
Have a damp meter in the van and give it a test every few months, was nice and dry last time I checked a few weeks back. There is nothing that can't be fixed with a hammer😜😜
Post #330637 2nd Jun 2015 7:17pm
acc
United Kingdom 2003 Range Rover Vogue SE Td6 Java Black
Hi all,
Here's my offering to the tintent brigade.
Alan
Post #331401 7th Jun 2015 4:46pm
Looks like a Bessacar to me👍 There is nothing that can't be fixed with a hammer😜😜
Post #331545 8th Jun 2015 5:13pm
acc
Spot on, it's Bessie 645.
Post #331673 9th Jun 2015 4:48pm
Andrew5331
Post #331759 9th Jun 2015 11:11pm
