Home > Technical (L322) > Brembo refurbishment
I am looking into having my brembo calipers rebuilt at a company in Long eaton. Was thinking of whipping them off on the drive, and taking them in. Not too bothered about getting them repainted, more about getting the internals replaced as I think they might be sticking and the last couple of times I have had the pads out the dust seals looked a bit shonky.
The plan is to clam the hoses off remove the caliper and put the wheels back on. The question is, is there any special method of bleeding required for the front brakes, i am pretty sure there are 2 bleed nipples to deAl with on each caliper, but apart from that?
Bow down There is nothing that can't be fixed with a hammer😜😜
Post #313378 18th Feb 2015 8:41am
pld118
This is the procedure listed in the 4.2SC section of the workshop manual.
Note that the manual simply distinguishes by referring to vehicles with high performance brakes and so the procedure will be the same regardless of petrol/ Diesel engine. The front Brembo calipers have bleed nipples.
http://workshop-manuals.com/landrover/rang..._bleeding/
Forum members have also recommended using a bleeding kit which makes the process easier.
http://www.screwfix.com/p/gunson-eezibleed...king%20url
Post #313383 18th Feb 2015 9:04am
They are around £300 a side for factory refurb'd units from MD if that helps any? Dan'll quote you happy Very Happy
Post #313394 18th Feb 2015 10:09am
cheers chaps, Might have a shout at Dan as the lead time for the refubs was 5-7 days which could be a little problematic having the car out of service that long. Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #313502 18th Feb 2015 7:00pm
NMJ if you go the factory refurb route then gloss Black ones (from the early SC) are the same price/same fitment/part and look much nicer Thumbs Up
Post #313511 18th Feb 2015 7:31pm
Top tip, cheers Craig.👍 There is nothing that can't be fixed with a hammer😜😜
Post #313541 18th Feb 2015 10:00pm
Post #313559 18th Feb 2015 11:42pm
Scottyav
United Kingdom 2007 Range Rover Autobiography TDV8 Zambezi Silver
Brembos for the win Thumbs Up Bow down _____________________________________________________
Zambezi silver Vogue Se unique Smile
Post #313565 19th Feb 2015 12:22am
