Home > In Car Electronics (L322) > Mk4 Follow Up Questions / Issues
CY
2002 Range Rover Vogue Td6 Epsom Green
Hi All,
I have just finished reading through all the threads on this, and think I've just confused myself further, so would appreciate any insight on this please Smile
I recently purchased a Mk4 system and installed it in the car. I purchased a 2015 DVD Maps disc online, with the v32.6 firmware with Range Rover flash screen. Here are my issues...
1. This is the most annoying problem!! Since doing this install, I am suffering from the problem of audio drop outs (for 1 second or so), intermittently. I have read the long thread about audio drop outs on here, and that appears to be to do with the TV region (I have tried this, but it hasn't sorted the problem). Any ideas?
2. I cannot get the speed camera announcements to say anything... When I go into the menu I get this display:
It looks like it's on, but it never announces any cameras of any sort....
If I click to turn them on and toggle through the choices, it suddenly changes the options and offers me German and Spanish:
3. What does the "Memo" option do in the settings page? When I turn it on I just get this little wifi symbol at the bottom of the screen...
4. My navigation won't display the estimated arrival time. It used to do this on the Mk3 unit Confused
All help much appreciated!
Thanks,
Chris 2002 Range Rover Td6 Vogue
Post #314675 24th Feb 2015 10:26pm
mjdronfield
I have the mk4 but I only use original bmw firmware with it, as camera warnings etc are not available from factory, so yours will not be original software. I know they sometimes give issues. That said, lots of people have non standard software and have no issues, so more of a heads up in case you were unaware.
The arrival time didn't show on mine and I had to use Navcoder to set the unit up properly
http://www.fullfatrr.com/forum/topic15145.html?highlight=arrival
To my mind there are only 2 options for tv
1 Get a hybrid unit from a later bmw, which is what I did
2 have your existing unit modded so all the internal bits are swapped. Said to be better than the genuine bmw unit....
http://www.carphonics.co.uk/digitaltv.htm 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #314686 24th Feb 2015 11:04pm
