Home > In Car Electronics (L322) > Main dealer batteries?
Scottyav
United Kingdom 2007 Range Rover Autobiography TDV8 Zambezi Silver
Just quoted 175+vat for tdv8 off landy, pal swears MD are the best ones to fit, any thoughts on better alternatives guys thanks 👍 _____________________________________________________
Zambezi silver Vogue Se unique Smile
Post #317998 14th Mar 2015 12:57pm
mzplcg
I fitted one of these to my TDV8. If you use the FBH it's a godsend being GEL based. It can start the car when 80% discharged and it will stand a lot of deep dishcharge cycles. Same price as LR quoting.
http://www.justcarbatteries.co.uk/index.ph...ttery.html
Post #318004 14th Mar 2015 2:54pm
wealy
United Kingdom 2014 Range Rover Vogue SDV8 Luxor
I think varta is fitted by land rover as standard AGM was fitted post 2009 I think
Post #320198 28th Mar 2015 12:32pm
SteveyD
England 2003 Range Rover Vogue Td6 Bonatti Grey
To a certain extent a battery is a battery. Internal components effect the lifespan, R&D contributes to safety, longevity and lifesian. Your looking at two main things the amps per hour (Ah) and the cold cranking amps (CCA). As a rule of thumb the higher the number the more power. You need high cranking amps for the FF and enough Ah to ensure it won't flatten quickly.
A high end Bosch will be significantly cheaper and come with a 5 year warranty. From memory I bought my 110Ah / 920 CCA for £130 all in. 5 min job to fit. Cost of saving = 1 tank of fuel.
Stevey
Post #320202 28th Mar 2015 1:12pm
Yes but the 110ah battery is a "difficult fit" in some tdv8s, I had to cut the bottom flange off mine which I would imagine has invalidated the warranty! Whistle There is nothing that can't be fixed with a hammer😜😜
Post #320213 28th Mar 2015 2:23pm
SteveyD
Good point NM but do you really expect any problems? Besides fitting stuff with hammers is mandatory on most DIY projects regardless Laughing
Post #320214 28th Mar 2015 2:29pm
Lad
England 2010 Range Rover Vogue SE TDV8 Santorini Black
I was quoted about £300 to fit a battery from dealer. I presume a 90ah one. But I sourced one for around £160. It being a varta with 110 ah. Unsure of cranking. May buy one, as the kids tv goes off after a VERY SHORT TIME after the ignition is switch off.
Post #320284 29th Mar 2015 1:35am
Scottyav
I got the md battery was 171 plus vat and is the dogs, popped the bonnet struts off lifted old out and put the new in five mins job 👍
Post #320288 29th Mar 2015 2:43am
Lad
I'll have another word with them to check price again.
Post #320338 29th Mar 2015 4:38pm
CEEGEE
Can't believe some of these crazy prices Shocked
Where I live we have a really good battery specialist (SYBS), who are the UK's largest independent distributor of Varta batteries and always give great advice of right ah for the job it needs to do.
I am sure they would be much more competitive than some of these prices and they never charge more than a fiver to fit, even if (as with some) its an awkward fit Thumbs Up
Post #320352 29th Mar 2015 6:06pm
