Home > Technical (L322) > obd2
obd2
am i correct in assuming that a basic obd2 interface cable connected to my laptop will only read and clear engine faults and light failure faults and if i wanted to clear an airbag fault or activate 'nav on the go' then i would have to pay the bloke in cyprus loads of money for a faultmate.. ... - .- -.
Post #28306 17th Sep 2010 3:48pm
dan_uk_1984
Correct.
USB OBDC Scanner for Engine Faults
iBus Interface for Nav/LCM mods
Rovacom/Faultmate/T4 for everything else.
Personally the idea of spanking hundreds of $$ on something that is locked onto one VIN number does not appeal to me in any way shape or form!
Post #28310 17th Sep 2010 4:09pm
what about light faults dan, ie replacing a halogen bulb with a led, can i clear that fault on the dash readout.would it be a usb scanner/interface ... - .- -.
Post #28311 17th Sep 2010 4:20pm
dan_uk_1984
That would come under LCM (light control module) mods
I turned off the bulb check for the side lights as I put LED's in there.
Dan
Post #28315 17th Sep 2010 5:58pm
so i need a ibus interface then, so as far as i know with mine being a touch screen and having a MOST system is there a an interface cable for this.. ... - .- -.
Post #28319 17th Sep 2010 6:16pm
dan_uk_1984
Is there any iBus stuff? Does yours still have a LCM?
Maybe give Daveo a nudge
Post #28320 17th Sep 2010 6:17pm
dunno re the ibus stuff, i know mine was in the cross over period from bmw to ford so maybe some bits are..bloody confusing this..thanks dan. Thumbs Up ... - .- -.
Post #28322 17th Sep 2010 6:20pm
daveo
scarey, there is a cheaper version of the unit you want, it will read and clear loads of stuff,from engine to air bags
https://blackbox-solutions.com/shop/ faltmat fcr 11
this is the same as its big brother but is big brother can write to the modules. as you know colin is the man to speak to, ohh the cheaper one can only be used on one car.
have a read up it is a very good unit for the price, nothing comes close
The Faultmate FCR is designed and manufactured specifically for Reading and Clearing all possible Fault Codes on every system with built-in self diagnostic capability on board each Land Rover model it covers.
Provided and priced as a personal use item for individual vehicle owners, the Faultmate FCR will lock itself to the VIN of the first vehicle it is used on, however, this feature also acts as a theft deterrent, because there is little point anyone stealing the unit, as once used on a vehicle, as it will not work with any other vehicle.
Each Kit comes complete with a FCR Unit, an OBD/Interface Lead, a USB Cable and User Guide - everything you need to start Reading and Clearing your Fault Codes. V8 facelift Range Rover Autobiography 22" wheels.
Post #28329 17th Sep 2010 7:28pm
thanks dave, i looked at the faultmate msv2 but at around £1k its way to much for the average diy'er..i'll have a look at that one but it would be nice to be able to buy a cable for £20 and get some software to do these things.. ... - .- -.
Post #28332 17th Sep 2010 7:43pm
daveo
i looked around for software and even bought some of ebay and none of it worked. not to say there is nothing out there. my mates AA laptop wont work on the range rover well my one. but some of that software is thousends to buy.... V8 facelift Range Rover Autobiography 22" wheels.
Post #28343 17th Sep 2010 8:49pm
if we could only get hold of THE proper software, now that would be good.. Wink ... - .- -.
Post #28345 17th Sep 2010 9:42pm
mzplcg
Yeah but even THE proper software won't do what a faultmate can Wink
Post #28419 18th Sep 2010 8:43pm
but its all down to cost as well... ... - .- -.
Post #28420 18th Sep 2010 8:46pm
mzplcg
Compared to the cost of dealer diagnosis on faults and also the cost of adding options to the car, some of which even the dealers can't do, (D3 cruise control for example) I don't think it's unreasonable. A fair chunk of money maybe but even at about £1k, if it saves you £2k over the years then it was a good investment, yes?
Then consider the value of having it in the glovebox to clear the odd fault, not that Land Rovers of any sort ever have those Whistle
And the bit about it being tied to one VIN is not strictly true. This can be changed for an upgrade fee or an open license can be purchased which is obviously a much larger chunk of cash.
Post #28422 18th Sep 2010 8:57pm
GKP
United Kingdom 2003 Range Rover Vogue 4.4 V8 Cairns Blue
Yep, the MSV2 Nano was one of the first tools I bought for my current car and replaced the unit I had for my old P38. Sure it's an expensive initial outlay, but it means I can tackle any job on the car without issue.
It's more than paid for itself by negating the need to visit the main dealer on three separate occasions - all of which were simple sensor failures (maf, lambda and abs sensor) but would have meant three lots of diaganosis and three lots of spannering all at main dealer prices.
(Edit to add: I also recently discovered a fault with the leccy part of the thermostat which didn't pop any lights up on the dashboard and as winter is approaching it's nice to have that working correctly)
If you decide not to replace your current RR with another, there's always a strong secondhand market for the units and you'll get a significant chunk of money back on your outlay. Not sure you should be reading this bit.
Post #28441 19th Sep 2010 12:12pm
