![]() | Home > Technical (L322) > Hard Ride? |
Garyfax Member Since: 02 Feb 2015 Location: Halifax Posts: 124 ![]() ![]() ![]() |
Hi Folks.
Everything appears normal, everything
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8808 ![]() ![]() ![]() |
What size wheels are you running?? Pete
Bellini Member Since: 11 Jan 2012 Location: Berkshire Posts: 2261 ![]() ![]() ![]() |
I'll be watching this with interest as mine is the same.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8775 ![]() ![]() ![]() |
As above, check the tyre pressures and if it bothers you and you are running on 20" then try some 19" as the ride is slightly better.
Hard ride! |
Yes the wheels I have are 20", I will check, tyre pressures. What would you recommend to put in them, its usually
32-36psi |
hoppy_70 Member Since: 04 Apr 2010 Location: Peoples Republic of Mancunia! Posts: 870 ![]() ![]() ![]() |
Mine has 20's and the drive is very comfy. I can literally take speed humps without slowing down. I believe the original principle was that the range rover should be driveable over a ploughed field at 70mph. Suppose a lot will depend on what you came out of/ perspective. Bmw m sport or rolls Royce phantom? My Previous RR's!
Chillb Member Since: 25 Jul 2012 Location: Portsmouth Posts: 142 ![]() ![]() ![]() |
Garry hi
I find my D4 will corner slightly better than the FFRR, lets not forget though it is basically a more practical RRS. There is nothing that can't be fixed with a hammer😜😜
Thanks for the advice folks.
JPS Member Since: 10 Sep 2012 Location: South East England Posts: 565 ![]() ![]() |
Mine was like this and was down to worn suspension bushes, changing them to new ones made the world of difference |
