![]() | Home > Technical (L322) > HDC and Air Suspension Inactive warning signs |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3271 ![]() ![]() ![]() |
Re the diagnostics, it's Gap iiD . Do a search onthe forum and you will get plenty of information. Thoroughly recommended piece of kit. HTH John
nicksaab Member Since: 28 May 2013 Location: Wimbledon and West Wales Posts: 560 ![]() ![]() |
I'm sure an expert will be along in bit, but you'll soon find out that all those lights come on when the air suspension is playing up so you probably only have one issue.
6029 king Stephen Member Since: 11 Apr 2015 Location: Sittingbourne, Kent Posts: 101 ![]() ![]() ![]() |
Thanks for the responses so far. I saw a YouTube video with the person resetting it by going from lock to lock so I tried that but it hasn't worked. I will try a search to see if there is anyone in Kent who can help me and search for the tool.
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3982 ![]() ![]() ![]() |
I'd also be inclined to look at the condition of your battery and the voltage put out by the alternator.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8782 ![]() ![]() ![]() |
Yep, agree, my money is on battery and/or alternator to put those lights on....
Michael27 Member Since: 11 Dec 2012 Location: UK Posts: 22 ![]() ![]() ![]() |
In West Africa now, don't do it!!! |
Was it this one by any chance....
Yes, Haylands it was! A really genuine seller and the vehicle performed faultlessly the whole way and not as thirsty as I was fearing - about 18 mpg. In total, around 1,200 Km for the journey.
47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048 ![]() ![]() |
No point resetting the suspension if there is a fault |
Should have added, if you can't tell, I love it. I will never tire of the V8 noise on start up, on pulling away and on kick down! The wife loves it too, which is good as she will be driving it in Africa to go to play golf etc.
OK but don't I need to establish whether there is a fault? My suspicion after reading other posts was that when the vehicle was washed, they use a high pressure hose to wash down the windscreen and the vehicle front and the damp of the sensors and after the rain that began no sooner than the car had been cleaned, might have attracted dirt to the ABS or another sensor and this is what is confusing the sensors.
There is a full workshop manual in the wiki called Rave (top of page under fullfatrr.com)
I went to Bourne Performance in Sittingbourne and after doing the left and right lock, they reset the codes. The warnings disappeared from the dash. I drove to the other side of town and reversed parked on a downward slope and the warnings reappeared. Last Saturday I went to RCV in East Peckham and they plugged their diagnostic machine in and once again, after doing left and right lock they reset the codes and the warnings disappeared. I then drove to Maidstone, to Halfords where the car was booked in for a Bluetooth installation and when I parked up, the warnings reappeared.
Bizarre on Halfords - when I bought my 2004 there was a Parrot already installed and a receipt in the glovebox from an install done by Halfords.
