![]() | Home > Wheels & Tyres > Speedo difference between 20" and 19" wheels? |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8093 ![]() ![]() ![]() |
It's the tyres that matter
Roystonh Member Since: 21 Nov 2011 Location: Kent Posts: 395 ![]() ![]() |
They are official LR, so that should be OK then, cheers! 2005 L322 Vogue Gold gone
33CHINACARS Member Since: 14 Apr 2011 Location: Tyrendarra, Victoria, Australia Posts: 381 ![]() ![]() ![]() |
If you run stock size tyres on 19" & 20" they will be the same .
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
The 19's are 0.004" bigger than the 20's, and I'm not even going to bother trying to work out how much faster you'll go on an extra 4 thou, it will be a fraction of a mile an hour when your flat out. The speedo's read slightly over, so there is no way you'll set a camera off, providing you stick to the speed limit |
Here's some interesting reading for you
From an online tyre calculator
