ok, lets get the low down about reprogramming second hand keys..does it work or not, there are many on ebay to be had...
1st thing, of course you will need a new blade cut, this can be done easily..
2nd, on older keys that have a separate transponder chip like the 02 to 05 keys these can only be programmed once and as yet i haven't found any one that can supply them as they are rolling codes,
3rd the blip part, there are several ways of programming them I.e ignition on/off hold button down ect ect. do any of these work, if so please let me know
reason why...my key went through the wash, still works but the batt goes flat with in a few days
must be shorting out in side under the battery plastic and i will have to unsolder it and try to repair it.. but i wanted to try to program a second-hand key to open and lock just encase this went wrong
i can get a new key from the dealers but they want you to pay up front, and you have the option of ordering number 1,2,3,or 4 on the keys, there is no info on my keys to tell me what number i have and they cant tell me, so if i buy a number 3 key and my spare key is a number 3 key the new one will knock my old one out and it wont work,"back to one key" if your ignition has been changed then the key wont fit at all.
the best bit is you wont get your money back
any idea of what the best ting to do is... V8 facelift Range Rover Autobiography 22" wheels.
