![]() | Home > Maintenance & Mods (L322) > New car, what do I need to do? |
You are very right about using tapwater. My 06 4.2 blew both heat exchangers due to the bloody tapwater they put in. I was not amused to say the least |
chex Member Since: 17 Sep 2012 Location: E. Africa Posts: 130 ![]() ![]() |
It's a 4.4 petrol. I'll change fuel/oil/pollen filters.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35692 ![]() ![]() |
buy an iidtool, it will become invaluable where you are.. ... - .- -.
Thanks, that's on the list too. |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
buy a forum sticker!
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8616 ![]() ![]() ![]() |
You don't do anything to the hydraulic side of the brakes when changing discs, ask them to change the fluid whilst they are doing the discs, will be cheaper than doing it on its own...
viper Member Since: 11 Apr 2015 Location: manchester Posts: 271 ![]() ![]() ![]() |
owners workshop manual says use freshwater in the coolant. however if I lived in a very limescale area in the south I think is use rainwater , filtered . Up here our water is very soft with very low mineral contact |
Changed coolant last night. Radiator and coolant reservoir are new, which is nice.
VANOS noise is gone with oil change \o/
Last night after being on the road for about 15 hours with no problems it started bogging down and losing power. I pulled over and gave it a few minutes and it was fine.
Bstrong Member Since: 11 May 2015 Location: United Kingdom Posts: 5 ![]() ![]() ![]() |
Found your post re: power loss when searching for the same issue. You find out why it does it? |
It hasn't done it again but I assume it has something to do with a vacuum leak.
