Home > In Car Electronics (L322) > L322 Rear Camera 2011
Mchoody
United Kingdom 2011 Range Rover Vogue SE TDV8 Orkney Grey
Hopfully someose can assist, I need to replace the rear parking sensor as mine has a strange line accross the screen when operating. (The actual screen is ok as the nav and TV still works perfectly)
I did order a new camera (being a little but tight from ebay) but it was a genuine Land Rover part that shoud have fitted my model year but doesn't.
The camera I have is part number LR031812 and has 4 pins showing, the one I need (picture attached) looks like a single pin with 2 smaller pins above. Any ideas???? Cheers.
Post #325917 4th May 2015 10:54am
Mchoody
Any reason this has been moved? I would think this definitely falls under maintenance. It's a replacement of an existing part.
Post #325919 4th May 2015 10:58am
There are two camera versions available for your rear end sir... Does yours have vision assist? (mirror mounted camera’s & alike) if it does NOT then you have a fixed type rear camera! If you have V.A. then you have a moving rear camera sir... Thumbs Up
Would appear you now have one of each sir Whistle Rolling Eyes
Post #325921 4th May 2015 11:01am
heppsen
Germany 2012 Range Rover Vogue TDV8 Santorini Black
a "moving" rear camera? Sure?
moving in the sense that the lens can move?
regards
heppsen 2017 MB V-Class
2016 Q7 (gone)
2012 FFRR TDV8
2012 Smart Pulse Turbo
1986 MB W126
1965 LR Series 2A
1961 LR Series 2
Post #325930 4th May 2015 11:39am
i think its the guide lines that move.. ... - .- -.
Post #325931 4th May 2015 11:42am
I believe you can pan in and out (as well as the lines moving with your steering inputs) too can’t you? Remember JC on his first test panning in on a lovely young lady in the car behind him stuck in London traffic... Whistle
Post #325934 4th May 2015 12:02pm
Mchoody
Thanks for the replies. I'll give Dan at Duckworth a shout tomorrow and find out the bad news. Looking at the description it did say fixed but i suppose that's the gamble of ebay! There may be a camera for sale very soon..
Post #325937 4th May 2015 12:19pm
So, does yours have VA or not sir?
Post #325938 4th May 2015 12:23pm
Mchoody
No, no vision assist on mine.
Post #325940 4th May 2015 12:37pm
In that case, if you find a used one? Make sure it is not defective! Big issues with the pictures reversing on the early cameras!
Post #325961 4th May 2015 3:49pm
Mchoody
I'll just get a new one now, don't really have the time to keep swapping out!
Post #325971 4th May 2015 5:04pm
