Home > Maintenance & Mods (L322) > Trickle Charging
Rangeyman
As seems to be the case that the RR uses lots of battery when not in use,what exactly is using this power and realistically with a good battery what should it last for unused.What amps should it draw when off as I have a clamp meter just to check?
Post #326385 6th May 2015 5:45pm
J evro
England 2008 Range Rover Vogue SE TDV8 Stornoway Grey
I've got the Ctek7, never had a battery problem since, just use it with a ctek extension so it reached the outside power socket on my drive and then run it through the bottom of the tailgate rubbers and into the 12v in the boot , prob hook it up twice a month if not using the FF for a week or so Thumbs Up
Oh and it comes in a storage bag that I drape over the front seat/ steering wheel to remind me to unplug before driving off Whistle
Post #326389 6th May 2015 5:50pm
Ethanicus
England 2010 Range Rover Vogue SE TDV8 Stornoway Grey
When using the supply feature on the ctek 7, I'm assuming you can leave the battery connected without issues. 2010 - Range Rover VSE 3.6 TDV8
2014 - Defender 90 XS
2014 - Suzuki Swift Sport
2017 - GBS Zero
2006 - BMW Z4M Coupe (gone)
2004 - Discovery Landmark TD5 Auto (gone)
2008 - Defender 90 SX (gone)
2011 - Touareg Altitude (gone)
Post #326391 6th May 2015 6:03pm
Robert
France 2007 Range Rover Vogue 4.4 V8 Zambezi Silver
That's a good idea Evro, that bag on the front seat Thumbs Up
Post #326410 6th May 2015 6:58pm
Weegie
Yes no problems. John
GAP iiD BT-Sold
Post #326413 6th May 2015 7:06pm
n1cktdv8
I have a DIY solution in place right now !!
Bought a 13 pin caravan towing plug, fitted with a 10A fuse and red + black wires cabled up and then plugged into my existing Ring Digital 16A (running at 8A)...no messing under bonnet. Will do this once a month and see how it goes.
£14 and all sorted Thumbs Up Is this where I put the car details and a bit about myself ?........
Post #326415 6th May 2015 7:26pm
DannyH
England 2002 Range Rover HSE 4.4 V8 Zambezi Silver
My Celica alarm used to drain the battery after 3 weeks of no use so I use a ctek msx5.0 and just leave it all the time on the winter setting. Got a2 meter extension and some extra cable, spliced together to make a7 meter cable and it reaches from my shed across the drive to the car.
Will this be ok for the RR or is there something that might prevent me doing this?
Post #326416 6th May 2015 7:27pm
Ethanicus
Weegie wrote:
Yes no problems.
Thanks, charged over night and sorted the issues I was having. Now leave connected to a baby check (0.Cool when not using in the week via the tow socket. 2010 - Range Rover VSE 3.6 TDV8
2017 - GBS Zero
Post #327327 12th May 2015 8:42am
