![]() | Home > Technical (L322) > Sump plug won't come out |
PaulM Member Since: 08 Mar 2015 Location: Warwickshire Posts: 190 ![]() ![]() ![]() |
Tried to drain the oil & the sump plug won't come out. I undone it no problem, wasn't overly tight but it only unscrewed a few turns & is now loose but can't pull it out, it just spins loosely. Had to leave it on a slow trickle to drain out. 2004 RR 4.4 V8 Autobiography |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
Can you get a knife blade or similar in behind the head of the plug to apply some pressure as your turn it. Might come out, but then you have the problem of getting it done up tight again |
I'll have to give it a try tomorrow, weather was horrible today so i left it. The oil has drained out now so maybe just do it back up. Question is why has this happened, never had a sump plug just get stuck. My thoughts were its stripped the thread but then it would just come out I would have thought. 2004 RR 4.4 V8 Autobiography |
DannyH Member Since: 30 Apr 2015 Location: Hull Posts: 221 ![]() ![]() ![]() |
Stripped half the thread off the bolt, some thread on the inside of the sump is still fastened to the bolt and therefore the sheared part of bolt is just spinning and the remaining good bit of thread is stopping it coming out further?
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
Sounds like a nightmare to me!!!
Craig, this whole car is a nightmare............ If it wasn't an Autobiography I think I would be looking at starting a Range Rover breaking business with this being my first victim😁
Found myself whistling when i read Dan’s “look on the bright side” good old monty python |
I hear that Craig |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1845 ![]() ![]() |
All may not be lost
to be fair guys, I've not even picked up my first ever RR yet (tonight at 6 - get in!) so I could be classed a naïve to the up and coming headaches that I'm likely to face! Dan
Bryan N Member Since: 01 Jan 2014 Location: Cambridge Posts: 68 ![]() ![]() ![]() |
Paul,
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
if its stripped and wont tighten without dripping/gushing etc, then, you could just remove the lower sump, and fit a secondhand one. cant really be more than about £50 on ebay, if not too goosed around the threaded area, then drop it into a machine shop to drill out and fit a larger sump plug etc. plenty of larger ones available. its just a typical bolt really with a copper washer! could even be grease tapped from underneath.
Well I've been out today & it did tighten back up after I got it to catch. I would still like to know the issue but without removing the sump I won't really know. I'm not even sure if it's the correct bolt, do they have two washers or is it yet another bodge I've found? 😁
That's not the correct bolt.
