Home > Maintenance & Mods (L322) > Aux drive belt TDv8
viper
United Kingdom 2007 Range Rover Vogue TDV8 Zermatt Silver
Aux drive belt TDv8
what is the service life on these, was thinking about changing it as preventative maintenance
cant really see to inspect
Post #326938 9th May 2015 8:20pm
they never seem to mention changing them, I did mine when the alternator went south at about 68k, the old belt didn't look too bad to be honest but they are fairly cheap, a bit fiddly to change though. There is nothing that can't be fixed with a hammer😜😜
Post #326995 10th May 2015 10:08am
nzlandrover
New Zealand 2007 Range Rover Vogue TDV8 Java Black
Hi there.
I changed mine a month ago.
Intercooler hoses off.
Top water pipe off.
Airbox out.
Fan cowling unclipped.
Left hand thread on viscous fan.
I downloaded a whole heap of serpentine belt routing diagrams on a PDF and used it for reference.
My 2007 vogue has done 216,000kms and I don't think it had been changed,then it snapped,only half the width of the belt was in the guarding.
I think the steering,charging etc is now much better.
Post #329325 24th May 2015 10:45pm
viper
thanks for the info on the change, its now on my short term list
Post #329326 24th May 2015 10:47pm
martinf
United Kingdom 2016 Range Rover Vogue TDV6 Santorini Black
I had mine changed and the idler pulleys replaced when the alternator failed at about 70k miles
Post #329357 25th May 2015 10:56am
viper
what was the condition of the belt ?
Post #329365 25th May 2015 11:46am
martinf
Dealer said belt was OK but as it was so hard to access and it was not expensive I had it changed anyway.
Post #329368 25th May 2015 12:00pm
Zirconblue
I'd always chuck a new one on there just for peace of mind if i was replacing anything else they required it's removal.
It's a bit like replacing a clutch when a gearbox or engine is removed for something. For the sake of the parts cost it'd daft not to.
Post #329413 25th May 2015 8:43pm
