![]() | Home > Maintenance & Mods (L322) > Bumper off - really???? |
Bomb Doctor Member Since: 18 Dec 2014 Location: West Midlands Posts: 15 ![]() ![]() |
Hi All,
markcaughey Member Since: 03 Nov 2014 Location: Glasgow Posts: 316 ![]() ![]() ![]() |
Bumper does not need to be removed ! 2 scews at the top and one at the side then just pull it out. I had mine removed when replacing the bulbs takes about 2 minuets . They probably just say that to cover themselves as lots of cars will require the bumper off to get the headlights out
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3271 ![]() ![]() ![]() |
Don't know if there is any difference in MYs but I changed the complete nearside headlight unit on my MY2005 L322 in February without removing the bumper. It was straightforward. John
marky777 Member Since: 05 Mar 2015 Location: Christchurch Posts: 141 ![]() ![]() ![]() |
Hi bomb d, would this upgrade be the same for my 05 ajv8 as your 07? Ithink they have the same front end? So is the conversion aimed at making it more like a 09 onwards style? And finally roughly how much and where? Sorry for all the questions but i like the idea of the led's |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
that's a fair point, mine has the original type head lights with wipers. The facelift ones might be different. |
Does this help?
As said If the car has the standard 2007 front end then the only part that has to be removed is the grill, then its just 3 screws, 2 at the top and 1 at the side then just lift the headlight out . Range Rover Vogue 2006 4.4 AJV8 | Buckingham Blue | Parchment Leather | Supercharged Grill+Side Vents | CA02 HEY ( NOT 02 PLATE ) |
i see the lower bolts i mentioned are the wash/wipe mech mounting. |
If you scroll down through the comments on the video link you will see that someone (Scottyav actually |
It does, to a point, but my MY is 07 and the lights are different. |
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1529 ![]() ![]() |
I've got the 06 MY S/C and you don't need the bumper off as said above, take the grill off (three screws) being careful of the temp sensor wire and then there are three screws Philips #3 IIRC
