Home > Technical (L322) > Routine operation of the transfer 'box
How often do you operate the transfer box of your offroad vehicle?
Weekly when I check oil and tyre pressures etc
25%
 25%  [6]
Monthly as per LR recommendation
37%
 37%  [9]
Annually if I remember
37%
 37%  [9]
Errrrrr, what's the transfer box, I will never take it off road so I'm not bothered if the next owner has to fix it
0%
 0%  [0]
Total Votes: 24
IanV8
Scotland 2011 Range Rover Vogue SE TDV8 Santorini Black
I use it when manoeuvring the caravan mainly because it modifies the accelerator response making it easy to move slowly, the extra torque helps with going up onto ramps as well.
Ian
Post #29819 29th Sep 2010 12:50pm
SteveMFr
Site Sponsor
None of the above for me.
I use my RR's off road. And while, especially in the case of the LM, that isn't monthly, it does happen several times a year at least - so I don't worry about it.
Like Ian, I also use low at times to maneuver my trailer when it's particularly heavy.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #29830 29th Sep 2010 3:05pm
Vogue
yep Thrasher is right a low box is merely just an extra set of gears.
You could drive 500 miles with it and not do any harm as long as you don't over rev the engine. I have one vehicle that is almost permanently in low box, its used off road and on hard tarmac roads heavy towing - never ever an issue.
Post #29838 29th Sep 2010 3:24pm
Well, would you believe it, the day after I posted about it not coming back to high(normal) ratio having tried weekly for two years, I tried it today, and it came back from low to high - three times in a row. Not holding breath but thatnks for the karma Tim Laughing
And thanks all for the confirmation re low ratios, as I thought Smile .
Post #30023 30th Sep 2010 6:06pm
tis fate joe..... Thumbs Up ... - .- -.
Post #30029 30th Sep 2010 6:29pm
Tim in Scotland
Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland
2010 Range Rover Vogue TDV8 Stornoway Grey
Bow down glad to be of service, I only do miracles when there is a blue moon 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #30047 30th Sep 2010 7:54pm
