Home > Maintenance & Mods (L322) > Engine Oil Overfill
shalz
Kenya 2011 Range Rover Vogue TDV8 Santorini Black
Engine Oil Overfill
Hi,
So I've been pretty neglecting. Had the FFRR serviced end April and only just checked engine oil level tonight (thanks to me being off the ball and partly to the complicated way to check as no dipstick) where it first showed level as OK then as overfill and to check manual immediately. Reading manual says to contact assistance as overfill could lead to serious engine damage.
Its been over a month since the service and I've used the car for one long trip and lots of small to medium trips. Haven't noticed anything wrong but understand there could be issues caused. I'm calling the garage tomorrow to let them know and to check the car and drain excess oil but I have some questions:
1. What can an overfill of engine oil lead to? I can't tell how much extra has been put as electronic dipstick.
2. What can I ask garage to check to see if any damage has been done?
3. How do they know how much oil to drain due to electronic dipstick?
I appreciate many will say a good garage will know what to do but I'm in Africa and good garages dont exist ....! MY11 Vogue 4.4 TDV8 - "African Queen"
Post #331417 7th Jun 2015 8:30pm
chex
Kenya
Everyone here does this, even the specialist Subaru guys did it to my legacy and I had white smoke out the exhaust.
I read up on it at the time and basically what can happen is:
- The crank beats the oil in a froth and it loses lubricity so your bearings die
- Excess oil gets into the piston bores and can damage the rings
- Gets into the combustion system and burns, some gets into the exhaust and can damage the cat
- You could also end up with a runaway engine
There's no decent mechanic for the newer range rovers. The head mechanic at BHP was also head mechanic at the Tz LR dealership but that's also where my Subaru was overfilled. If I had to choose I'd say either go there or Ndovu. Schumacher almost killed my car, would never recommend.
I do my own oil changes now.
Post #331420 7th Jun 2015 9:00pm
shalz
Chex - thanks for the info. Which garage is BHP?
Service was actually done at N*** so will obviously be taking it back there but shame such a small oversight could lead to such big problems. I'm stuck between letting them rectify or taking it to RMA and getting them to sort even though it will have costs!
I'd love to have the ability to service the car but just know I'll probably make it worse.
Touch wood have not noticed any change in performance - am hoping it is more that the overfill is by 0.5l or something small. I hope they have a way of telling how much extra oil is in there somehow MY11 Vogue 4.4 TDV8 - "African Queen"
Post #331421 7th Jun 2015 9:10pm
chex
Kenya
BHP is on Ole Odume Rd but seem to focus more on Subaru/rallying so I'm not sure if they even do LR. (070) 500-0385
Ndovu would probably deal with it if you call and complain - the owner is super anal.
Post #331423 7th Jun 2015 9:22pm
bebechoon
France
I accidentally overfilled my 2005 Td6 once (up to the dipstick max level, or so I thought …) which eventually resulted in masses of smoke (and I mean masses – really very embarrassing amounts!) coming out of the exhaust. Just draining off the excess wasn’t enough - oil had got into the intercooler so that and the hoses had to come off to be cleaned out.
I understand that if you get to that sort of situation (where you have oil in the air circuit), there is the risk the motor will run on the oil fumes and you won’t be able to turn it off. Indeed it could over-rev to the extent of destroying the engine.
Get it fixed quick! It's "bébéchoon", ackcherly, with accents. 'Steve' to my chums.
20 years ownership of Solihull products, ALL GONE NOW, sniff!
Current motor: Suzuki S-Cross 4WD auto, 1.4 petrol. Oh so reliable! 7 years now and no problems. Oh, all right then, a leaking shocker replaced under guarantee.
Previous:
TD6 HSE L322 Auto FF
2.5 TDi 4-door Classic
Disco II
And my 1st Rangie: in 1995, a 2-door VM 2.5 diesel Classic
Not to mention the Lada Niva before those. (I said not to mention it!)
Post #331426 7th Jun 2015 9:42pm
Zirconblue
If it's really over filled then the oil system can over pressurise and blow seals. The engine can also burn it and burning lots of it can damaged the lambda sensors and cats.
Basically you can just check the car over for oil leaks and do an emissions check. If that checks out ok then any damage is likely insignificant.
To drain it the best way is with an oil syphon via the dipstck tube, some cars have a dipstick tube with a cap on the end for just this purpose (why the hell they don't just put a dipstick in it i don't know!) they can just suck out say 1/2 a litre then see where the level is and just take a little at a time until its right.
The other option is just to drain all the oil and refill with the correct amount of new oil, no real need to change the filter if it's recent though.
Post #331428 7th Jun 2015 9:48pm
Zirconblue
It's theoretically possible with a diesel for it to run on it's own sump oil, and you hear lots of people mentioning it on the internet and in the pub, but i'm yet to meat anyone who's actually had it happen to them. It's always a mate of a mate had it happen to him, or their brother's wife's, 3rd cousin once removed's boyfriend's dad had it happen to them.
You can always turn and engine off - just stall it. A diesel running on sump oil is unlikely to have a great deal of power, so should be pretty easy.
Post #331429 7th Jun 2015 9:53pm
dingg1
I've seen it happen on a turbo diesel - not a jot the driver can do about it and it leaves a REALLY impressive smoke screen
I'm sure you can google it on youtube
Post #331431 7th Jun 2015 10:01pm
Zirconblue, ive had it happen to me twice sir... Both in TDi’s one FF one French and on each occasion the turbo let go and it drank the sump dry within seconds! Finished the Peugeot 1.9 TD engine (so had to be replaced) hydrolocked the 3.6 TDV8 FF which damaged an injector and snapped the starter motor! But the engine survived Shocked
Post #331432 7th Jun 2015 10:09pm
Zirconblue
Some how i knew as soon as i posted that someone would be on here saying "I'm always doing it!" Laughing
Post #331449 7th Jun 2015 11:37pm
Rolling Eyes Whistle Thumbs Up Laughing
Post #331477 8th Jun 2015 9:22am
CS
I (2012 TDV8) had the same concern, as the screen was showing the oil level above the maximum. As recommended in the handbook I called the dealer for advice and was told (1) the oil level has to be checked cold, not warm after settling for 5 minutes as would have been the case traditionally; and (2) the oil level test is very sensitive to the angle at which the car is standing so for example in my garage which has a slightly uneven floor I get different readings depending on where it is. Testing cold the level showed about a quarter below the maximum or about the maximum, depending on where it was in the garage. I was also told that if it really was overfilled the car would not be running right, so if yours is running well it might just be a case of testing it cold and on a level surface.
Whether it is a good design to make the oil level test only possible when cold and on a completely level surface is of course another question.... Only Range Rovers since 1988
Post #331509 8th Jun 2015 12:04pm
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
I did see a youtube vid of an X5 (edit found below)killing itself when it became a turbine. I guess in a manual you could try to stall it, less possible in an auto!
As said, hell of a smokescreen!
Post #331513 8th Jun 2015 12:47pm
^ thats a proper de-coke!!!! ... - .- -.
Post #331514 8th Jun 2015 12:53pm
Stephen.125
@Stan Laughing Laughing Cool
Post #331519 8th Jun 2015 1:49pm
