Home > Maintenance & Mods (L322) > Basic air-con check?
Brian
My air con does not seem to do anything - so I'd like to check it myself (as far as I can) before going to get it looked at by a mechanic - I rang the previous owner to ask if they had maybe disabled it but they say they never used it as they were told it "used too much fuel" and they just opened the roof and windows - now I'm heading to a car show tomorrow and I know its dusty out there and would like it to work (my local Halfords can check and re-gas it if needs be) so is there a basic "to-do" list first? like fuse or belts? I suppose I should read the manual but I usually like to ask other owners first in case it's something silly and I go up to Halfords and they tell me the belts been removed (or something equally as daft)
Post #333326 19th Jun 2015 12:30pm
best left to the experts ....if the a/c has never been used then theres the possibility that the seals have dried up so unless you are very lucky it might be an expensive repair.. ... - .- -.
Post #333328 19th Jun 2015 12:35pm
Might just need a gas recharge. If they've never used it, as Stan says, the seals might have gone off, but a quick trip to KwikFit for a recharge might do the job. if the seals are OK, job's a good 'un, if not you may have to investigate further.
Does it blow air at all? Got - 2017 SDV8 Autobiography in Loire Blue
Post #333332 19th Jun 2015 12:49pm
Weegie
Wherever you go ask them to do a leak test as recharging with a leak will only mean losing the gas. John
GAP iiD BT-Sold
Post #333333 19th Jun 2015 12:55pm
ebajema
Unfortunately, the idiots that owned it did you a diservice. Like Stan said, the seals are likely to have dried out, the coolant (and lubrication) gone so if you try to run it (for a while) it is likely to do some damage.
On my 4.2 (that had been sitting in a yard for 2 years in Nigerian heat) that is what happened. After a year of use the system failed (although I should have filled first before doing anything else) and I had it replaced.
My suggestion is, fill first and see if it works. If not, go to a specialist and find out what is wrong. If you are very lucky, it is just a refill and the seals are OK. If not, it will be empty soon and then you can look at having the seals replaced or the compressor replaced. MY 2010 5.0 SC Galway green and sand interior!!
Post #333337 19th Jun 2015 1:20pm
Proper A/C people will leak test first before adding any gas Thumbs Up .
Post #333353 19th Jun 2015 1:57pm
Zirconblue
If the gas has leaked out, then the compressor clutch will be disabled by the pressure switch, so running it like it shouldn't do any damage.
No harm in checking the fuses though, it might just be a blown fuse.
Presumably you got it cheaper because the AC wasn't working?
Post #333399 19th Jun 2015 5:45pm
sasdiscos
United Kingdom 2010 Range Rover Vogue SE TDV8 Zambezi Silver
Needs testing with ofn first.
Steve You remind me of a young me, not much younger mind, perhaps even a little older!
Post #333406 19th Jun 2015 6:06pm
kwik fit can do a vacuum test on it and a pressure test to see if there is any gas in the system, and whether there is a leak.
It could be a few reasons it doesn't work:
No gas - bad leak with a hole in the condenser etc
No gas - seals gone bad through under use
fuse
compressor
compressor clutch not engaging
start with a garage or outlet with a proper re-gas system which will put a negative pressure into the system, to check for leaks, if they find some they will then put a UV tracer into the system to locate where it is seeping out, this will tell you what the problem is and how to fix it. Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #333417 19th Jun 2015 6:51pm
Brian
Cheers - Just found out local garage has the kit to test and recharge etc so will leave it with them - hopefully its something simple Cool
Post #333488 19th Jun 2015 10:56pm
destructimo
United Kingdom 2004 Range Rover Vogue 4.4 V8 Epsom Green
Hi Brian,
Mine packed up recently after not being particularly impressive last time I used it last year. Laughing
Main dealer said the compressor wasn't running and that it 'could' be the gas / liquid ratio gone off or something more serious.
Main dealer £90 to squirt some gas in there or £49 for Halfords to purge / test and refill.
A couple of hours on Halfords' machine has it icy cold now with a UV trace in case there is a small leak somewhere.
Happy days!
Cheers
Clive
Post #333720 21st Jun 2015 11:24am
