![]() | Home > General > How Noisy is a V8 Supercharged? |
3528cc Member Since: 29 Oct 2014 Location: North East Posts: 301 ![]() ![]() ![]() |
My SC is very quiet, suspect something is adrift with the engine Regards
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1852 ![]() ![]() |
There was a TSB released about noisy timing chains |
Road Stone Member Since: 08 Mar 2014 Location: Uganda Posts: 227 ![]() ![]() ![]() |
Thank you for the replies
The 5.0 is also direct injection which can sound a bit rattly. The injectors are quite noisy for some reason. |
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 ![]() ![]() ![]() |
I have a 4.2 in my jag and you can't hear it running on tick over
Thanks Guys,
SHOULD STILL BE SILENT! |
Nomad Member Since: 26 Oct 2011 Location: Ringwood, Hants Posts: 300 ![]() ![]() ![]() |
My newly acquired 5.0 s/c is also a bit rattly at idle. The dealer I bought it from said there was no problem but that as it is under the two year warranty I could get if fixed if it gets worse. Above mzplcg suggested the 5.0 Direct Injection may be more rattly than the 4.2. Any other 5.0 owners with comments? 2012 5.0L S/C
mine is the old 4.2 and is whisper quiet.
Neither do I know, it just is. I have the 5.0 Rangie (2nd one now) and SWMBO used to have the 4.2 Jag. The Jag was definitely quieter. |
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 ![]() ![]() ![]() |
I've the Jag 4.4 NA. It's quiet when started cold. Once warm, it is almost silent. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8768 ![]() ![]() ![]() |
DI petrol engines are just a little noisier, swmbo has a direct injection Skoda and it can sound a little diesely at times, when pulling off from a hill start for example but at Tickover it is quiet. There is nothing that can't be fixed with a hammer😜😜
nemmi69 Member Since: 16 Jun 2015 Location: Peterborough Posts: 108 ![]() ![]() ![]() |
Def should be no smell of petrol! Rings may be stuck (petrol fumes pushed past in to crank case vent system). Redex or similar may help. |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6378 ![]() ![]() ![]() |
The 4.2 SC on tickover at warm can be so quiet you wonder if it's running - I know this cos NRK tried to start his up one day when we were sitting at the Eurotunnel and found it was already on.
