![]() | Home > Technical (L322) > Oil Suction 4.4 TDV8. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8774 ![]() ![]() ![]() |
I think It's just next to the oil filler cap. Small black cap with a circular arrow on it. (Assuming that's what it is for in any case.) the cap twists off and pulls up.
There is what looks like a dipstick tube front left with a black twist top |
That said, I’m not sure a Pela siphon will fit down it |
Looks like it's designed to have a connector pushed on the top and the tube itself acts as the siphon pipe. There is nothing that can't be fixed with a hammer😜😜
Never seen the JLR system I’m afraid... |
stoutgoose Member Since: 08 Jan 2015 Location: London Posts: 188 ![]() ![]() ![]() |
Thanks all, found it. That is indeed a very thin tube! |
Does your Siphon tube fit? |
Nope! However problem solved here; I turned the car around because it was on a slight slope and problem solved!
