![]() | Home > Technical (L322) > Small Pipe Right Hand Side of the Engine Block |
| johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035
i'm not familiar with your model, but range rovers have some breather pipes fitted, to the axles and i think gearbox, and starter motor, they are black or white, and made of stiff nylon, and have a rounded end around 2 inches? to allow air to exit or enter when said items warm up, but (hopefully) not let in water when wading etc. Hence they hieght, and safe position,at rear etc. |
| Mcnallykev Member Since: 19 Jul 2015 Location: Lanark Posts: 172
Ace thanks! I didn't look like it should be connected to anything but thought I better check! |
| Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277
No they just vent to the air. On the Range Rover's they're raised right up, so that if you go and drive through a flood (wading) the water doesn't get into them. |
| lee37Vernon Member Since: 12 Oct 2014 Location: Aldershot Posts: 74
Sounds line the transfer box vent, mine wee'd a bit after playing up the woods! Had to follow it back down to see where it went, I extended mine upwards a tad so it drops back into box rather than drips on my rocker cover.. 2003 4.4 Adriatic Blue FF |
