This is my old rad, removed from car, hose in top hole, this is the flow from the bottom feed to the gearbox cooler
This is the same with a new rad...
Trans cooler can fail internally and put water in gearbox, it can also get blocked with old dirty oil and the pipes often collapse internally and block flow...
If you having gearbox overheat problems I'd do the lot, new engine rad, new oil cooler, new oil cooler, oil cooler thermostat and manifold and new cooler lines...
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Pete
-Click here for Thread-
