Home > Maintenance & Mods (L322) > angel eye fogs/drls
Page 2 of 7 <1234567>
have them fitted and am well impressed,
pic with new halo/cob unit and my old led one ,
pic of both fitted,
i'm well impressed with the brightness considering it is bright sunlight.. ... - .- -.
Post #339516 28th Jul 2015 11:39am
J90
France 2006 Range Rover Vogue Td6 Java Black
Are these a straight swap Stan. How do you select the DRL? How do select the cob? If it ain't plug and play I haven't a clue as to how you would fit these.
Post #339520 28th Jul 2015 12:04pm
J90
They do look good Stan Thumbs Up
Post #339521 28th Jul 2015 12:07pm
Thumbs Up thanks..
they are not plug and play unfortunately...you need to adapt and fettle these into the existing fog enclosure.. ... ... - .- -.
Post #339524 28th Jul 2015 12:14pm
supershuttle
Stan,
I hope those LEDs across the front of your grill don't strobe across to the Nightrider music Rolling with laughter Geoff
Post #339527 28th Jul 2015 12:24pm
Very nice Stan... What are you doing with the ones you took out...??? Pete
-Click here for Thread-
Post #339539 28th Jul 2015 1:11pm
@geoff....er, they actually do Embarassed Mr. Green
@pete.....i'm keeping them for a bit to make sure the new ones work ok ... ... - .- -.
Post #339545 28th Jul 2015 1:59pm
horse86
United States 2014 Range Rover Autobiography 5.0 SC V8 Causeway Grey
Very nice Stan!
I was about to get those LED jobs after seeing yours but these look even better! How does the quality look in person? I wouldn't want a cheap PeP Boy special looking lamp.
As far as mounting is it just mating it up to the stock bracket or do you need to trim and hack up a bracket or something to work?
How do you wire up the halo vs the projector? Do you need to splice the stock wiring?
We need more pics daytime and nighttime beam shots!
Kudos again...I may be getting a pair myself! Very Happy 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #339550 28th Jul 2015 3:07pm
horse86
also is the projector LED as well or halogen? Very curious to seem beam intensity and width. 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #339553 28th Jul 2015 3:28pm
thanks chap. Wink
the light unit is very well made with a bit of weight ...its smaller than the fog enclosure so a strip of window/door insulation tape is needed around the lens part.. this will make a snug fit in the enclosure...
at the back of the unit are two small screw holes which accommodate the bracket..i found some longer ones which would go from the outside ....
the diameter of the back of the light unit is 20mm smaller so you need to put 10mm thick packing in..
my halos are wired to a drl switch and i've not wired up the the cob projectors, but they can be fogs or whatever you want.. ... - .- -.
Post #339554 28th Jul 2015 3:31pm
horse86
great writeup!
Now we just need some night time beam shots Thumbs Up 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #339567 28th Jul 2015 4:30pm
pics taken at 7.30 tonight with just the halos/drls on,
Post #339589 28th Jul 2015 7:36pm
supershuttle
"@geoff....er, they actually do Embarassed Mr. Green
aaarrrggghhhhh Censored Big Cry Rolling with laughter Very Happy Geoff
Post #339594 28th Jul 2015 8:00pm
J90
Stan what do you use the front LED light bar for? Is it just for fun?
Post #339615 28th Jul 2015 9:52pm
yes, just for fun Wink ... - .- -.
Post #339623 28th Jul 2015 10:07pm
