![]() | Home > Maintenance & Mods (L322) > angel eye fogs/drls |
pietertje Member Since: 30 Nov 2014 Location: Rotterdam Posts: 152 ![]() ![]() ![]() |
Tx David. But without your crystal clear instructions i would have been nowhere...
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35832 ![]() ![]() |
look good [like mine do |
Today finally got into working on the center LED's.
what are you using the centre led for ? ... - .- -.
Want to use it as a fog light... 2002 L322 V8 |
why not connect them directly to the fog light feed... ... - .- -.
Wish life was that simple....
they are connected straight onto the fog feed wires, no flickering as i have turned off hot and cold monitoring with the iidtool....very bright as well..
Well they are bright when I use them with the relais, only then there is the flickering and ticking sound.
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3983 ![]() ![]() ![]() |
Disconnect the wire on terminal 30 of the relay and leave the relay connected to the original foglight connections. Does the relay still chatter when the foglights switch is on ?
@nicedayforit
No I think the problem is the hot and cold monitoring is operating continuously as the resistance of the coil in the relay is too low for the monitoring system to measure.
To resolve the flickering problem I think you need to fit resistors across the wires connected to terminals 85 and 86 of your relays. The type of resistor is shown below.
Thanks For looking into this.... I will order a pair...
