![]() | Home > Technical (L322) > A/C icing, evaporator temperature sensor? |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3667 ![]() ![]() |
Hi all, got issues with the A/C, the temp goes up and the air flow drops. From what I can make out it's the evaporator icing up, also I regularly get vapor trails coming from the centre vent (mini clouds). Has anyone got any thoughts |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35841 ![]() ![]() |
i'd go and see a doctor re that last one .. |
You'd know all about that bud |
Re-circulate is off, no lights at all so I will take that as fresh air, which should be the least likely to cause icing, and clouds forming in the car |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8817 ![]() ![]() ![]() |
I would say it is low on gas, had two cars in the past that made clouds out the dash and both were fixed with a regas.... |
Sounds reasonable to me, try a re-gas before a dash removal, way easier to achieve |
If you had an IID tool you could check it yourself.... |
Dam Pete, your going to end as modded as your ffrr |
will be having a front one as well.... |
Ooooooooo Pete, just found this
Yes....... lose about 6 inches of ground clearance with that.... mind you at least you'd have a winch to get you unstuck.... |
Just stumbled on this if your going the D I Y route, might give you some idea's
