![]() | Home > Technical (L322) > Random suspension lowering when parked/locking doors. |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8776 ![]() ![]() ![]() |
When you are driving it is difficult for the FF to decide what is or isn't standard height, bends, pot holes, camber etc means that the system has to "guess" where it should be, when you stop and switch off it resets and goes to normal height (unless you pressed access) it will only do this with the doors shut so you see it do it after you get out...
horse86 Member Since: 09 Dec 2014 Location: PA Posts: 863 ![]() ![]() ![]() |
Ah ok...makes sense I guess. Was odd since my commute is mostly the same everyday and sometime it does it and others not. Just a quirky thing with the suspension....but man do I love the air ride comfort...so I'll put up with the quirkyness |
iKushtyy Member Since: 19 Apr 2015 Location: London Posts: 94 ![]() ![]() ![]() |
Self-levelling suspension.. Levels itself when car is at rest.. |
Fish Member Since: 30 Aug 2014 Location: Bolton Posts: 301 ![]() ![]() ![]() |
I've noticed mine do it occasionally when sat at traffic lights. First couple of times I wasn't sure it actually happened |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
Presumably the level sensors have small steps in them. If you're on the cusp of one of the steps the suspension might move from one step to the other as occupants move about in the vehicle. |
Hall effect sensor, totally linear, but the system has a + or - 9mm tolerance in standard mode...
