![]() | Home > Technical (L322) > Towing electrics |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
Most generic kits have a buzzer as it's cheap but I think though you just need a way of telling you when the trailer lights aren't working, the bulb check system should come up with a warning on the dash display if a trailer light fails i think.
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3665 ![]() ![]() |
I have genuine OEM parts fitted, all be it with Westfalia stickers, but they is genuine |
I think he means by satnav on the later ones, you can tell it what sort of trailer you have so it can adjust the electronic stability program to match it. ie. if it's a big heavy horse box, it's going to affect the handling more than a little box trailer. If you tell it you just have a bike rack it probably doesn't inhibit the suspension.
Fish Member Since: 30 Aug 2014 Location: Bolton Posts: 301 ![]() ![]() ![]() |
Does the sat nav not just adjust the route allowing for the trailer , i.e. Avoiding low bridges, particularly narrow roads?
It might do but very few bridges would be low enough to warrant a re-route for what ever you're towing with a Range Rover (i mean a horse box is what 8-10 ft high?) and most satnavs can just differentiate between major roads and minor roads, some minor roads are really quite wide. So i'd think it was unlikely and probably just to do with the trailer stability assist or what ever they call it. |
IanT599 Member Since: 15 Jun 2013 Location: Wellington Posts: 351 ![]() ![]() |
Yeah the camera system on mine can be setup for different trailers, caravans etc.
I think you're right, they've gradually added bits and pieces over the years. I think VW have a system that actually reverses the car and trailer combination automatically, similar to those automatic parallel parking systems you find on some city cars. -it's quite impressive really. I imagine we'll see that end up on a Land-Rover too if it isn't already.
I'm the one with out the light |
Ifor williams warn against LED lights, apparently you're lucky one some makes of car the lights wont work at all with LED's fitted. |
^ I am not in a position to dictate what type of lights are fitted to the many different types of event trailer that I tow |
There are adaptors that go between the tow socket and plug to counteract the led bulb error messages. Unsure if the cost of them.
It shouldn't be too difficult to make something, just a male/female lead with a box of resistors in the middle should do it.
I'm already there |
