Home > Technical (L322) > TD6 Gearboxes and towing
reb78
Hi All,
I'm new to the site, but am quite interested in getting a RR at some point soon. First question I have is that we would occasionally tow an Ifor horse trailer with a couple of 500kg horses in there. There are a number of nice looking TD6 RR for sale on here at the mo, but i am worried about the gearboxes if using it to tow. Any thoughts/advice on this?
If one of these boxes has already been replaced, are they usually replaced with modded boxes that are less likely to go again, or is it a case of 100K or so out of the recon box and then replace again (perhaps sooner if towing)?
Am currently using either our manual TD5 D2 or the 200tdi defender but fancy changing the D2 for a RR.
Post #346415 6th Sep 2015 7:46pm
vaz
United Kingdom 2007 Range Rover Vogue TDV8 Java Black
Depends on the deal you can get if the car has had the gearbox replaced or not.
If the car has done average mileage then the last of the TD6's will have around 85 - 90,000 miles on the clock. Provided the gearbox has had regular oil and filter changes during its life (Land Rover used to say the gearbox was sealed for life!!), then it is possible for it to do 150,000 miles or even further.
There again it could fail next week.
Buy one with a recent recon box then that will give you some piece of mind. Buy one with its original box, that could be a point to negotiate on price and have something in reserve for when the inevitable happens.
Take our purchase as an example.
120,000 miles but with a duff engine, whilst swapping the engine I had the torque converter reconditioned, changed the oil and filter in the gearbox (also had wrong oil or not genuine oil in the gearbox). No excessive particles were found in the sump of the gearbox at the time, so I left it as it was.
Done some towing, 5 times out with our twin axle caravan since mid April and a couple of favours for a friend by towing a recovery trailer with an old Range Rover on the back each time halfway across the country with no gearbox issues at all.
How long is a piece of string?
Steve. 1968 Series IIA Pastel Green, nearly there project
Post #346431 6th Sep 2015 9:33pm
RRPhil
The main failure mode of the 5L40-E transmission in the TD6 is through reduced hydraulic pressures caused by wear in the valve bodies from spool oscillation in the soft aluminium blocks.
These reduced pressures allow friction elements like the torque converter lock-up clutch to excessively slip until the friction lining wears away completely and the resulting metal-to-metal contact generates large quantities of metallic debris.
In the majority of remanufactured transmissions (and you can tell from their price) the transmission is stripped, cleaned out and the torque converter replaced. Clearly this doesn’t resolve the root cause of the problem (as the valve body assembly is left untouched) and the pressure - and therefore wear - problem immediately begins again but at an accelerated rate. Often the transmissions will just make it out of their warranty period.
Because of the nature of the failure the torque seen by the transmission has little bearing on its life i.e. towing and chipping the engine make very little difference.
For a durable replacement, therefore, the valve body assembly needs to have been replaced or upgraded with the Sonnax kits.
Phil
Post #346445 6th Sep 2015 11:25pm
Rosco
I have towed an Ifor with 2 17.2 warmbloods pretty much every couple of weeks for the last 9 years all over the UK. To be honest it is all that it does.
125000 miles and the gearbox hasnt been touched.
Is booked in for a service next week though as I have ridden my luck, pardon the pun.
Best of luck with your search Thumbs Up
Post #346448 7th Sep 2015 6:54am
reb78
Thanks. This is really helpful.
Phil, that's a really good explanation, thanks for taking the time to put the pics up.
Post #346451 7th Sep 2015 7:41am
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
RRphil real good explanation, my car was chipped on the basis it would prolong the life of the gearbox but 60k later and looks like being changed again and I don't tow only very small trailer to the tip and back. So I believe it's a case of when the gearbox will go and not if.
greg
Post #346456 7th Sep 2015 8:36am
