![]() | Home > Technical (L322) > Turbo cut in point |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35859 ![]() ![]() |
you've just spent loads on a FFRR and you're worrying about fuel consumption.... |
scanner Member Since: 14 Jul 2010 Location: Yorkshire Posts: 61 ![]() ![]() ![]() |
Look where I'm from, it explains everything |
When you turn the key.................. |
Tim in Scotland Member Since: 25 Mar 2007 Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland Posts: 2181 ![]() ![]() |
As Scarey says, forget worrying about MPG. If you are doing a long long haul then sit back and enoy the car's comfort, set the cruise at 70 and let it pur along at 1850rpm and it should settle down on the average mpg setting at somewhere in the region of 29-30mpg, a bit less if there are a few hills to climb, a lot better if it is flat lands you are driving. Just don't try to drive it like a GTi, then you will get low to mid 20's - leave GTI driving to the Saxo boys. 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes |
My question wasn't purely about fuel use. I seem to remember many years ago when I had an Isuzu Trooper which was turbocharged. When accelerating it made a pleasing noise as the turbo cut in and you seemed to feel the extra push. Since then I've driven diesel Beemers so have forgotten all this turbo stuff.
delamo Member Since: 17 Mar 2010 Location: Beaconsfield, Bucks Posts: 1121 ![]() ![]() ![]() |
You will love it scanner! ![]() ![]() |
iT LAD Member Since: 08 Jul 2010 Location: Surrey Posts: 1350 ![]() ![]() |
What colour combo have you opted for... |
Stornoway Grey, Charcoal Leather and Factory tints I think iT LAD ![]() |
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 ![]() ![]() ![]() |
It's a miss conception amongst drivers that boost is bad for fuel consumption. The reality is that without boost engines have to rev harder, and more of the fuel they burn is used to turn the engine than develop power.
Zermat Silver with Jet Oxford leather. No tints, don't do enuogh drugs for that ![]() |
