Home > Maintenance & Mods (L322) > Rear Landcover badge removal
ije44
United Kingdom 2007 Range Rover Vogue TDV8 Barolo Black
Hello all,
I want to remove the rear Landcover oval badge in order to fit a silver/black one.
What is the best way for getting this off without damaging the panel.
All suggestions welcome.
Thanks,
Ian
Post #347304 11th Sep 2015 10:10pm
Fishing line or dental floss.... Pete
-Click here for Thread-
Post #347306 11th Sep 2015 10:21pm
Warm it up with a hairdryer first
Post #347308 11th Sep 2015 10:26pm
ije44
That sounds like just the ticket, thanks guys.
Post #347312 11th Sep 2015 10:39pm
To get the sticky off get a toffee wheel off eBay. Fits in your drill, made of rubber, will gently on a slow speed erase the glue. Gently does it though so you don't damage the paint. There is nothing that can't be fixed with a hammer😜😜
Post #347318 11th Sep 2015 11:15pm
ije44
Thanks Northernmonkeyjones,
To be honest I had never heard of such a thing, checked eBay and they're not expensive so i'll get one.
Post #347322 12th Sep 2015 12:14am
Bit of petrol on a rag is cheaper.... Whistle Pete
Post #347329 12th Sep 2015 7:21am
mattstevenson2005
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
The rubber wheels are fantastic at removing the glue! Thumbs Up
Post #347352 12th Sep 2015 10:48am
I know mate, they are very good, but if he's only removing one then a bit of petrol is cheaper and I've found the Land Rover glue to be pretty easy to get off.... Pete
Post #347415 12th Sep 2015 5:59pm
Strider
I used boiling water when i replaced the oval Land Rover / Supercharged badge on the tailgate.
I carefully poured the water over the badges in turn then, with my fingernail and a thin piece of plastic slowly lifted one corner,and pulled each badge off.
The glue residue came off easily with WD40 and there was no damage to my paintwork.
Peter
Post #347571 13th Sep 2015 7:03pm
ije44
All great suggestions... Thanks for the replies.
I feel much more confident about doing the job now.
Post #347591 13th Sep 2015 9:29pm
miggit
Shocked Pete you forgot to say DON'T use a match Wink Yesterday I couldn't spell Engineer... Today I are one!
Post #348095 16th Sep 2015 8:38pm
ije44
So the job is done. In the end I went with boiling water to soften the glue. I then used dental floss to slide under the badge and it came off reasonably easily. Then used petrol to clean off the residue, which it did easily and with no damage.
Thanks to everyone who replied with their suggestions.
Post #349423 25th Sep 2015 9:53pm
