Home > Technical (L322) > ignition lock slow
RichTDV8
United Kingdom 2015 Range Rover Vogue SE TDV6 Corris Grey
ignition lock slow
hi all
have a problem with my ignition lock. if the car is left for a few days the ignition lock barely comes to life and is very slow but is fine after the cars been running. Battery is fine less than 12 months old.
could I need a new barrel for the ignition??
thanks Previous
2008 TDV8 Vogue
2011 TDV8 AB (former LR1)
3.0VSE - 2015MY
Corris with Black, RSE, 22 turbines, privacy, deployables
2023 L460 P400 SE in silicone silver
2022 L460 P400 AB in black with ivory (fully loaded with deleted rear exec pack)
Post #174055 23rd Feb 2013 1:59pm
SoggyBottoms
United Kingdom 2007 Range Rover Vogue Supercharged Zambezi Silver
I found mine was slow when the battery hadn't been charged / topped up for a while
I put mine on a C Tek every month and replaced battery for 110
Post #174073 23rd Feb 2013 5:36pm
RichTDV8
thanks SB it definitely only happens when left for a few days Previous
2008 TDV8 Vogue
3.0VSE - 2015MY
Post #174128 23rd Feb 2013 10:55pm
my battery started feeling low on power only after about 10 months, mainly cos i didnt use it very much, as said above charge it up or get a replacement. ... - .- -.
Post #174158 24th Feb 2013 10:14am
Mine did the same, and now it doesn't work at all! TBH I don't care, as I know if I investigate it the dealers will tell me it's a new steering motor or something that will cost me a fortune. Discovery 4 HSE
1993 90 Tdi
Post #174165 24th Feb 2013 10:34am
Get the automatic in/out with ignition cycle turned off via diagnostics... Will also save the life of the motors too Thumbs Up
Post #174179 24th Feb 2013 12:07pm
Robgosty
United Kingdom 2007 Range Rover Vogue TDV8 Zermatt Silver
Know this is an old thread but I have same problem with ignition lock slow to respond when key inserted, this was after a hard battery reset, I am aware steering column movement can be removed but post from Craig seems to suggest ignition lock can be coded out, if so can it be done with IID tool ?
Post #347502 13th Sep 2015 10:17am
