Home > Technical (L322) > Trans Failsafe Prog - 2004 RR 4.4
Hi Guys,
Occasionally I get the dreaded 'Trans failsafe Prog' flash up when the car is started from cold and gear is selected.
I only occasionally have this message directly after starting the car when it is cold and usually after backing out of my driveway and shifting from D to R it will go into D with a thump then the message will display, it has never happened whilst driving, or when the car is warm.
It can always be cleared by turning ignition off and restarting, but I would like to get it resolved as do not want to case further harm to the transmission.
Have any of you guys experienced a similar issue? 2004 4.4 Autobiography - gone
2014 4.4 SDV8 VSE - gone
2012 4.4 TDV8 Overfinch
Post #349207 24th Sep 2015 8:21am
you'll find this is a very common error message and could be a number of causes, try a search.. ... - .- -.
Post #349213 24th Sep 2015 9:03am
RRPhil
A failing inhibitor switch or low battery voltage would be my guess. It would be worth checking if a P0705 error is stored in the controller.
Phil
Post #349216 24th Sep 2015 9:22am
V8Noise
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Carpathian Grey
I have heard that allowing the car to go through it's electronic checks before actually starting the engine can help solve spurious messages.
Turn ignition on, watch all the various lights go out (there are a couple that stay on, start engine, hopefully no more nasty's. 2017 5.0 Autobiography Supercharged
2005 Merc SL350
2005 Disco HSE 2.7 oil burner
Post #349221 24th Sep 2015 9:54am
L19 MUD
United Kingdom 2009 Range Rover Vogue SE TDV8 Stornoway Grey
I bet it is the xyz range switch - as suggested check for codes
Post #349310 24th Sep 2015 7:27pm
