Home > Maintenance & Mods (L322) > Sound Proofing
Page 2 of 3 <123>
GraemeS
Australia
stan wrote:
http://www.fullfatrr.com/forum/topic15612.html?highlight=sound+proofing
My oversize spare tyre does not sit on the floor of the well so the floor is free to resonate from the rear tyres and those of passing trucks!
Post #350313 2nd Oct 2015 12:33pm
Interestingly the quietest tyres on camskill in a 255/50/20 seem to be Hankook:
http://camskill.co.uk/m77b0s255p124731/Han...se%3A_69dB
Which have a class 1 69db rating. 3db better than the Scorps. Not heard of anyone fitting them though.....
Wet grip is only an E though Shocked There is nothing that can't be fixed with a hammer😜😜
Post #350420 3rd Oct 2015 8:38am
Cavalier
2011 Range Rover Vogue 4.4 V8 Orkney Grey
Just been out to have a look at the spare wheel compartment and I can't see any sound proofing in there at all, just bare panels and floor, I think I will buy some dynamat or equivalent and have a go at sound proofing this area.
Just another point: how the hell are you supposed to lift the spare wheel out of the well, impossible when your an old git like me. Big Cry
Post #350508 3rd Oct 2015 6:08pm
sako243
You need to be young and small so you can straddle the wheel well. Or if you're old enough JLR assume you can pay someone to do it for you... Whistle Ed
Post #350509 3rd Oct 2015 6:41pm
johnboyairey
I'm sure in the manual, it shows you that lifting the 'lid' with the strap connected, it slowly lifts the wheel, then you pull another strap to tug it out.
Not mine, it has an LPG tank,
Post #350521 3rd Oct 2015 8:15pm
GraemeS
Australia
No lift strap on my MY12 so just have to stand inside facing out the back and lift the wheel straight up then onto the tailgate.
Post #350522 3rd Oct 2015 8:48pm
sako243
Ironically I find it easier with the tailgate shut because being a shortie I can lift without reaching over too far. Ed
Post #350524 3rd Oct 2015 9:00pm
Spare wheel lifting strap available to retrofit, bolts in behind the wheel below the rear seats, loops under the wheel then when you need it hook it into the top of the lower tailgate and drop the tailgate down, this lifts the wheel so it can be slid out Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #350526 3rd Oct 2015 9:29pm
Yes as above... Retrofit the 02my strap system Thumbs Up
Post #350542 3rd Oct 2015 11:10pm
Cavalier
I managed to get the spare wheel out after a bit of huffing and puffing, I needed to do this as I want to sound proof the spare wheel well. The next time the spare is needed, I will be calling the AA.
I received 20 sheets of Silent Coat today, £49 from e.bay. I will be fitting tomorrow, pictures will follow.
Post #350939 6th Oct 2015 8:50pm
Cavalier
Well I prepared the spare wheel area for sound proofing
Made a start on the left hand side looking in from the rear
Getting there, I took the silent coat up the back of the jack position, over the top and just under where the rear seats are
Nearly there now
I had some spare foam cushioning in the garage, so added it to the floor around the compressor
And now the finishing touch, wheel back in and secured, the blue bag at the bottom left of the picture is my tow hook, sits snugly in the sponge, it has to go here as it is not a LR tow hook so does not fit in the recommended place.
Well after a good drive round, I am convinced it has improved the drone from the boot area Thumbs Up
Post #351079 7th Oct 2015 7:35pm
mjdronfield
Looking good. Just hope that foam doesn't get damp or wet or it'll smell a bit..... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #351091 7th Oct 2015 8:42pm
GraemeS
Australia
I did mine today although basically only the flat areas in and around the well - silence is golden! The front needs attention now so will start a couple of exposed side panel areas under the bonnet.
Post #351180 8th Oct 2015 10:07am
Have you considered the lower tailgate at the rear. I found it has no sound deadening material in it all and was very "tinny" when I tapped it. Adding sound deadening sheet significantly improved it.
The best way to do the bonnet is to remove the sound insulation sheet and stick patches of sound deadening material in the recesses formed by the bonnet framework and refit the insulation sheet.
Having looked at mine there is there is a built in weak point as regards getting rid of engine noise into the cab. Namely the plastic housing that contains the cabin filter. This plastic housing extends significantly into the engine bay and although it has a sheet of insulation material on the engine bay side I suspect this is inadequate and that a lot of engine noise can pass through the insulation sheet and the plastic wall of the housing and into the cabin by way of the ventilation / ac system.
Imo the insulation sheet needs to be removed, sound deadening material fitted to the underside of the plastic housing and the insulation material refitted.
I you want to be really pedantic there is also a path for sound to pass into the cabin by way of the air duct from the "electrical box" in the engine bay to behind the dashboard.
When you have a TD6, every little helps. Thumbs Up
Post #351186 8th Oct 2015 10:29am
GraemeS
Australia
I don't hear engine noise even though the engine acoustic cover is not fitted, only reverberation from the BFG AT tyres. The noise seems to mostly be emanating from the ends of the fascia although I know that the source of noise is often hard to pinpoint.
Post #351187 8th Oct 2015 10:45am
Page 2 of 3 <123>
